1995 Bronco ABS Brake Problem
Old Aug 5, 2003 | 06:37 PM
alvaalleniii's Avatar
alvaalleniii
Question 1995 Bronco ABS Brake Problem
I recently replaced the master cylinder on my 1995 Bronco. Since, I split one of the piston sleeves that are located on the front of the ABS hydraulic control unit. The split occurred in the o-ring recess directly behind the threads. I got another hydraulic control unit for parts and replaced the piston on my old unit. During the initial test drive, the same piston split again. Any ideas?
Old Aug 10, 2003 | 08:57 PM
steve83's Avatar
steve83
Replace the HCU as a unit - don't try to rebuild it.
gthbryce
May 25, 2009 07:47 PM
bigwillie
May 14, 2006 05:13 PM
ynot2244
Oct 2, 2005 09:29 PM
95fordbronco302
1978 - 1996 Big Bronco
Mar 6, 2002 04:29 PM
