what to do now for performance?
Old Aug 5, 2003 | 05:51 PM
moore89's Avatar
moore89
I own a 1967 F100 custom cab with a swapped in 351W 2BBL (by previous owner). I will be installing a custom 2.5" exhaust from the manafolds back to two Flowmaster 40 series mufflers dumpped at the axle. My question is what mod should i do next?
I want to keep the stock heads for now. Any ideas?
Old Aug 5, 2003 | 06:01 PM
84bronc's Avatar
84bronc
Add an aluminum intake and a 4 barrell carb, atleast that is what I would do next.
Old Aug 5, 2003 | 06:52 PM
90f150moneypit's Avatar
90f150moneypit
Yep the intake should be next. Then if you still want more, swap to a better cam.
Old Aug 5, 2003 | 09:00 PM
moore89's Avatar
moore89
my friend is giving me a great deal on a holly truck avenger carb, what would be the best intake for it and my stock heads? and how agressive can I go with the cam woith the stock heads.
Old Aug 6, 2003 | 08:46 AM
quentrm250's Avatar
quentrm250
What size carb.?
My machinist says to be safe he suggests staying at .500 lift or under on stock heads (it's always a good idea to double check).
If your on a budget I would suggest a Crane Energizer kit in the 270's series. Approx. $100 with lifters.
Edelbrock dual plane intake or maybe a Holley Dual Plane.
Old Aug 6, 2003 | 12:59 PM
90f150moneypit
I would swap in a Comp XE262H and a 650 Vacuum secondary carb on top of an Edelbrock Performer. These will work great with your stock heads and dual exhaust. From your stock 2bbl, it will be a day and night difference!
Old Aug 7, 2003 | 08:59 PM
fordguy351w's Avatar
fordguy351w
if your more for speed than torque you can also go with a performer RPM intake
Old Aug 8, 2003 | 02:01 PM
DW2455's Avatar
DW2455
I agree with the intake and carb but i would go with a good electronic ignition system first, if you gona give it more air/gas to burn, you need to give it a way to burn it! and what about headers for your new exaust? DW
Old Aug 8, 2003 | 06:03 PM
moore89's Avatar
moore89
I will be getting an MSD ignition soon, and I really want headers but I am unsure of which ones will fit my application
(1967 F100 with swapped in 351W)
Old Aug 8, 2003 | 06:43 PM
DW2455's Avatar
DW2455
Give SUMMIT RACING EQUIPMENT a call they can hook you up. i've spent way to much money with them over the years, I personaly always liked the (HEADMAN) and (HOOKER) headers best, but that not to say there arenot other good ones out there!
good luck with! DW
