Others can chime in about the carb and manifold, I'm not too familiar with the inline 6 department for that kind of stuff. Most order from either Jegs, Summit Racing or eBay. Or scan the local Craigslist for used parts.
The best "bang for your buck" is an EFI exhaust manifold, they are about 20 bucks at your local junk yard.
Intakes ect are pricey for a 300! My plan is to buy a 2 to 1 adapter that will allow me to bolt on a 2bbl to the 1bbl intake. The catch is only a holley 2bbl will bolt up.
Efi exhaust manifolds and the Walker Ypipe will flow better than stock but you will lose the heated floor to your intake.
This isn't a great situation if you live in a cold climate.
You are going to want a heated carb spacer or an intake that accomodates hot water.
Clifford and Offenhauser are the two that I know of.
Thats what I'm looking to do with this also what adapter and carb you plan on going with
What do you mean by EFI exhaust manifolds? And yes I live in North Dakota and plan to drive it all winter so definitely not a good plan
As was mentioned, the split exhaust manifolds found on later fuel injected engines flow much better than the single manifold found on carbureted models.
But I-6 engines have both the intake and exhaust hanging off the side where the intake is not warmed by the engine or coolant flowing through it.
This is a utility engine.
You CAN add performance, but will lose utility.
I'm not sure what you are hoping for, but you might be better off with a 351 truck instead of a 'tractor'.
