Sponsored by: Real Truck
multiple shocks
Old Aug 5, 2003 | 03:11 PM
tyme chaser's Avatar
tyme chaser
multiple shocks
just wondering your opinions on wether it would be smart to go with dual shocks up front. i have alredy chosen to go with bilsteins. the plow i use is about 750# and i would like to go with a set of 19.5 rims and tires at some point down the road.
this is my first post although i have ben reading the fourm for a while.
Old Aug 5, 2003 | 05:12 PM
99f350sd's Avatar
99f350sd
multiple shocks
Don't forget keep the truck height stock when using the plow. I don't think you will benefit from dual shocks even with the plow.
Old Aug 5, 2003 | 07:11 PM
Overkill's Avatar
Overkill
FTE *******
multiple shocks
tyme chaser,
What is it that you are trying to achieve? Dual Bilsteins will do a better job of body roll control but will do so at the sacrifice of some ride plushness. Hope this helps.
Old Aug 5, 2003 | 08:34 PM
tyme chaser
multiple shocks
just did not know wether one shock would handle the weight of the psd, the plow and a larger set of rims and tires.
