stereo faceplate?
Old Nov 2, 2015 | 06:54 PM
greenf150flareside's Avatar
greenf150flareside
stereo faceplate?
Is there any type of faceplate or finishing trim piece that i can get to cover the poor cutting job the po did for the radio?
Old Nov 2, 2015 | 07:41 PM
Franklin2's Avatar
Franklin2
You should be able to find something in one of the stereo installation kits like these.
Car Audio Installation | Stereo Installation Kit | Car Stereo Install | Installation Kit for Car Stereo | by Scosche
Walmart carries some of these installation kits, there may be something in one of them you can use. A lot of them have bezels in the kits as you can see in the above link.
ctubutis's Avatar
ctubutis
You might look at some aftermarket installation kits to see if there's trim that would fit around that aftermarket radio.
Old Nov 2, 2015 | 07:42 PM
ctubutis's Avatar
ctubutis
Wow, me & Dave said basically the same thing at basically the same time! How cool!
Old Nov 2, 2015 | 07:49 PM
greenf150flareside
Thanks for the link... Ill be sure to check it out.
Old Nov 2, 2015 | 10:02 PM
Lowpala's Avatar
Lowpala
Single din trim
It looks like your head unit is missing the trim that snaps directly around the faceplate but one of those (see link) may work.
Or get fancy and go with a double din install kit for a single din unit. Just cut your hole to fit and then you gain a little space to throw random things. I've seen some double dins that have slide out cup holders too.
dustyroad
38
Oct 1, 2019 12:06 PM
Midnight Garage
Jul 5, 2017 04:58 PM
Bronco2x84
Nov 21, 2011 07:12 PM
chriskoz
Feb 7, 2008 03:07 PM
swinehart07
Dec 17, 2007 09:37 AM
