95 Explorer 4.0 ball joints
Old Aug 5, 2003 | 02:34 PM
sman2050's Avatar
sman2050
Just took the old explorer to the dealer for a sfty recall. Front a sway bar links. The front left sway bar link was completly gone. While there they told me that both ball joints need to be replaced. Just had the car inspected for the MA sticker a month ago and ball joints are checked then. Could they have gone bad in just a month I passed the inspection. There is no play in the stereing. Am i a victom of the delaer greed they wanted almost $500 for the repairs and is this somthing i could do by myself? any comments
Old Aug 5, 2003 | 05:11 PM
Toon's Avatar
Toon
Hi sman,
If there is any play in the (lower) balljoints you can feel it.
Put the front end on a jack, preferably supported under the chassis so with the wheel off there is no load on the triangle.
This vertical play you can feel by moving the brakerotor up and down.
A play of 1 mm is acceptable, if more the balljoint must be replaced (my '95 ex started "wobbling" in corners).
In The Netherlands I payd $34,- each and $28,- for each upper balljoint (connecting rod).
Not difficult to do it yourself, but a lot of labour and you need a hydraulic press for the lower balljoints.
For this reason the Haynes manual advices to replace the triangle as a whole.
As a home wrencher it took me a whole afternoon.
Success, Tony.
wastingas
Escape & Escape Hybrid
Aug 24, 2013 08:27 AM
hdman6
Jan 25, 2012 10:00 AM
cmjboyer
2009 - 2014 F150
May 19, 2010 11:58 AM
FallstonYJ
Mar 17, 2010 09:01 PM
vze2sgxa
Dec 18, 2005 09:11 AM
