Sponsored by: Real Truck
Unknown Hose
Old Nov 2, 2015 | 03:15 PM
rdbesq's Avatar
rdbesq
Unknown Hose
I was just under my 2000 F250 7.3l crew cab truck ang noticed a small diameter rubber hose dangling from my front drivers side brake housing area. It is attached near two other cables which are similiar to cables on the passenger side. I dont see a similiar hose on the passenger side. The hose is completely deteriorated and broke off up higher towards the engine. I cannot see where it goes.
Anyone have any ideas what it may be?
Thanks!
Old Nov 2, 2015 | 04:37 PM
Diamnd1's Avatar
Diamnd1
Is the truck a 4x4? If so, it may be a vacuum hose that actuates the front locking hub. Look for the nipple on the top of the steering knuckle where it should slide over.
Old Nov 2, 2015 | 07:22 PM
wrvond's Avatar
wrvond
Is it a hose, or a cable?
Or perhaps it's actually a tube. Usually when somebody sees a rubber tube that they can't identify, it turns out to be a vent tube for the axle.
These tubes are connected to the axle and then travel to a fairly high point and the end is clipped in place in a 'U' shape. These tubes prevent pressure building up inside the axle and blowing out grease seals, but are placed in such a way as to prevent water from getting in the axle when it is submerged.
Old Nov 3, 2015 | 07:10 PM
rdbesq's Avatar
rdbesq
Tube
I bet you are right. I haven't had a chance to crawl back under to check, but I do remember thinking it looked like the hose doubled back up by the engine.
Old Nov 3, 2015 | 07:11 PM
rdbesq's Avatar
rdbesq
Repair
If it is the relief tube, is it easy to repair. The tube has basically disintegrated.
Shortbox4x4
Sep 6, 2017 06:20 AM
RickBryan
Feb 10, 2011 12:06 PM
littlefoot
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Jul 10, 2008 05:47 PM
carrcreekcaller
Apr 6, 2006 12:04 PM
bcsbadboys
Jul 30, 2002 03:17 PM
