LED Swap
Old Oct 31, 2015 | 04:54 PM
1985 Bronco's Avatar
1985 Bronco
LED Swap
Here an LED swap I did on my bronco a while ago. I have seen LED swaps posted before, but all of them include repainting the cluster. I did not do that, and just though I would post it so you can compare the two. I used a write up that Rusty did as a guide:
https://www.ford-trucks.com/forums/1...storation.html
Bezel removed:
The LEDs that I bought on Ebay:
Installed, I think I have one bad one:
and here is a comparison, I didn't have a good before picture, but you can see that they are brighter:
Old Oct 31, 2015 | 07:19 PM
SVTDriver97's Avatar
SVTDriver97
Good job man.
Now if only you can paint the cluster and then we can compare it to what it would look like with it that way?
Old Oct 31, 2015 | 07:30 PM
FordFETruck's Avatar
FordFETruck
Did you remove the filters inside the cluster? here's what mine look like without the filters.
Note: color looks more uniform in person across the cluster.
As far as the bad LED, LED's only work one way. Take that one out and rotate the bulb holder 180*, it should work.
Old Nov 1, 2015 | 05:44 AM
86f250-rs's Avatar
86f250-rs
The eBay led's are not as bright as the name brand ones. I too bought ebay ones and were not pleased so I bought name brand ones and will now but the rest for my truck. Price is very expensive, but the results are miles apart.
Old Nov 1, 2015 | 11:23 AM
Rusty_S's Avatar
Rusty_S
Which ones did you buy from ebay?
I ask cause I only buy from ebay and I have better LEDs than I found name brand wise. Difference is to know what to look for. You want bulbs with the largest chips possible then second you want to go with Cree brand chipsets over any other brand as they are a high quality chip same chips used in name brand high dollar LED bulbs.
Old Nov 1, 2015 | 01:13 PM
FordFETruck
Mine are eBay LED's. Plenty bright.
Old Nov 1, 2015 | 01:46 PM
1985 Bronco
Thanks for the tip, I'll try that and see if it works
UpInSm0kE
Mar 27, 2018 12:02 PM
timbersteel
15
Feb 15, 2015 09:51 PM
CharlaineC
46
Oct 30, 2014 09:14 PM
whitesdford
Aug 8, 2011 04:00 PM
dgassett
15
Aug 6, 2007 10:35 AM
