Coil spring shims
Old Oct 30, 2015 | 07:35 PM
hoss73ford's Avatar
hoss73ford
Coil spring shims
I'm assuming that's what they are. It resembles a bottle opener. Anyway when I disassembled my '69 F250 front suspension parts to be powdercoated, one side was missing the piece. Was this a mistake by the factory or a usual thing ? I'm assuming these have something to do with height. The truck seemed to be somewhat level except the previous owner had different size tires on the front.
Old Oct 30, 2015 | 09:13 PM
HIO Silver's Avatar
HIO Silver
Post a pic?? I don't think I've ever seen one.
Old Oct 31, 2015 | 03:20 PM
ultraranger's Avatar
ultraranger
Does the shim look like 5355 in the following diagram?
http://www.fordification.com/tech/im...s/ibeams01.jpg
It shows this to be on '65-'69 F100-F250s but, these were not on my '69 F100. My truck also did not have the 3A016 I-beam downward travel limiting arms (don't know the official name for them).
Old Nov 1, 2015 | 10:38 AM
hoss73ford's Avatar
hoss73ford
YES it is part #5355. I would think one missing would throw the height off and the alignment. Anyway I found someone that had some so both sides will have one when I put it back together.
Old Nov 1, 2015 | 10:57 AM
ultraranger
The stock springs are side specific on your Bumpside, due to the roughly 2" offset, to the right of the trucks center line, of the engine/transmission. The right side spring will be shorter but have a larger wire diameter than the right side coil spring.
If you have the old springs out, now is a good time to replace them. Brand new Moog CC808 progressive rate coils are inexpensive, are brand new and will ride better than the old coils.
Moog Cargo Control Coil Springs CC808 - Free Shipping on Orders Over $99 at Summit Racing
Moog CC808 progressive rate coil springs on my '69 F100 (no spring shims at the lower ends of the coils).
Old Nov 1, 2015 | 06:25 PM
hoss73ford's Avatar
hoss73ford
sounds good, I never cared for when the front of the truck is lower than the rear so maybe I'll try a pair.
Old Nov 2, 2015 | 09:15 AM
Coastal68's Avatar
Coastal68
Great tip, thanks!
riverrat41
6.7L Power Stroke Diesel
Aug 12, 2012 06:47 PM
crestfallinman
Sep 1, 2011 07:42 PM
ford66
Apr 19, 2010 06:45 AM
CountryBoys98Ranger
1983 - 2012 Ranger & B-Series
May 19, 2007 01:11 AM
tatonka
Mar 20, 2005 08:25 AM
