1966 F 100 front brake conversion question.
I can maybe clarify real quick.
The FE engine was discontinued in 1976. No way to source an FE-based donor after that year.
Yes, if you have an F250 and want to keep the 8-lug then you'd want to likewise get an F250 donor. Same year ranges apply.
The 6 cylinder 300 was built all the way up until 1996 so that's not a limiting factor for the 6 cylinder guys so they can get a donor up to 1979.
Thanks for your reply.This is a 352 based truck but it's getting a fairly healthy 460 and a tremec transmission, I'm not going to install power steering so engine brackets are a non issue. Around here pickups are at a premium and half ton 2Wds are hard to find but econolines are all over and cheap so I was wondering if anybody here had sourced them for the spindles and discs and up to what year. There is a complete 90 e 150 on C/L right now cheap .
Roger Carter in Corbett Oregon installed 77 F100 disc brakes in my 66 F250 by swapping the I beams in from a 77 F100. He also swapped in a 460 and C6 from that same 77 and changed the rear end to a Ford 9 inch.
I don't know about Econoline I beams.
You might send a message to him since he is pretty knowledgeable about Fords of that vintage, having done it more than once. He's the guy I call when I have a question.
edsteffan
54
09-20-2015 11:19 PM
xgkrx
01-03-2013 03:53 PM
Chad63F250
01-02-2012 09:26 PM
big-papa
15
10-18-2010 08:34 AM
