starting problem, takes two times
Old Aug 5, 2003 | 11:51 AM
jhm's Avatar
jhm
86 F150 302 EFI, On the first try the engine starts easy every time, and then dies within a few seconds.
On the second try the engine normally starts easy and stays running with a little pump on the gas.
The question is what part is causing the engine to die on the first try and where is the best place to buy it?
Old Aug 5, 2003 | 12:08 PM
85F_150driver's Avatar
85F_150driver
is your choke working correctly? MIne does the same thing but mines carburated. soounds like a similar problem though.
Old Aug 6, 2003 | 10:20 AM
NorthernFord's Avatar
NorthernFord
efi engines don't have a choke, sounds almost like bad plugs/dirty injectors to me.
Old Aug 7, 2003 | 01:34 PM
Sebago Frye's Avatar
Sebago Frye
Try this, turn on your key for 5 seconds or until you hear your fuel pump stop running. Then try it, if it stays running, your fuel filter is plugged or your pump is weak. This is a common problem with the Fords I have owned. By the way, I wait the 5 seconds. I'm too cheap to replace the fuel pump.
Old Aug 7, 2003 | 02:28 PM
jhm's Avatar
jhm
The fuel filter has been replaced already so that's not the problem.
The truck is being run off the front tank only.
The duel tank fuel selector valve is stuck in the front tank position, and with the rear in-tank pump in operation the main fuel pump will pull the fuel from the front tank, so the pumps are not a problem.
Old Aug 11, 2003 | 10:44 PM
steve83's Avatar
steve83
Put a pressure gauge on the fuel rail and see what you have.
Old Aug 12, 2003 | 06:39 AM
jhm's Avatar
jhm
And what exactly will that tell me?
Is that something that your overheard someone say?
It will still show full presure coming off the main pump.
Woodhauler
Nov 18, 2012 03:17 PM
crossman55
Aug 16, 2012 01:50 AM
Olbeater
Nov 17, 2010 12:00 PM
Kurt Frome
13
Nov 18, 2003 09:09 AM
