Icp stumper
Old Oct 29, 2015 | 11:30 AM
Kula's Avatar
Kula
Icp stumper
So did 2 injectors truck ran great for a week or so then the other day stalled while driving. Get the icp code unplug icp truck runs fine except the odd hick up, then random after coasting once in a while truck stalls no codes let it sit then re starts runs fine. I cannot find anything else where people had similar symptoms. I have not replaced icp yet been working will do on the weekend. Any help is apreciated! !
Old Oct 29, 2015 | 11:37 AM
navistarnut's Avatar
navistarnut
Do you have a way to check ICP readings?
What year is the truck? Might simply be an ICP sensor.
How long does it have to sit? If it's a hot start issue might be an HPOP or leak somewhere, depending on what year truck is.
Old Oct 29, 2015 | 12:10 PM
Kula's Avatar
Kula
It's a 05, new ipr and hpop a month ago. This is with the icp unplugged cause I know it's bad so it's running off the default. Just a few min and it will fire right up.
Old Oct 29, 2015 | 04:10 PM
WatsonR's Avatar
WatsonR
did you pull the IPR and check for trash on the screen? Sometime after all that work, some junk is floating around and the screen just needs cleaned again.
ICP have oil in the connector? What was the code you got?
Old Oct 29, 2015 | 05:49 PM
cheezit's Avatar
cheezit
Does it have a p1000 or a p0603 code or is it really no codes.
Does the gpcm light come on when it stalls.
sleek122
Apr 8, 2015 12:51 AM
f1501987
31
Jan 13, 2013 01:16 PM
fridgeddiesel
Aug 21, 2012 09:06 AM
jrobs86
Mar 10, 2011 03:06 PM
devildog12210
Jul 5, 2010 10:55 PM
