Fog Light's??
Old Oct 30, 2015 | 02:48 PM
gwh1bass's Avatar
gwh1bass
Originally Posted by 03X
20" bar for me too.
Do the LED light bars mounted in the stock bumper opening impede the air flow to the coolers behind the light bars?
Old Oct 30, 2015 | 03:04 PM
03X's Avatar
03X
Couldnt tell ya. Doesnt get hot where I live so not really worried about it, and I dont tow so never working it hard. If you used the single row LED bar it would allow more airflow for sure.
Old Oct 30, 2015 | 07:57 PM
sdk1968's Avatar
sdk1968
really like the look of those 20" LED's!!
are you running those from the factory plug ?
Old Oct 30, 2015 | 10:28 PM
03X's Avatar
03X
Yes, my bar operates as the factory fog lights did. Removed factory fog lights and put a connector to the LED bar.
Mine is a spot/flood combo, I would not recommend it. I would use a narrow spot beam only if I had the chance to do it again. The flood portion blinds oncoming traffic so I cant use it on the highway much.
Old Oct 30, 2015 | 10:55 PM
Stewart_H's Avatar
Stewart_H
No more so than aftermarket bumpers that completely eliminate that opening.
Stewart
Old Oct 31, 2015 | 12:06 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
I'll be putting a set of Rigid Dually DOT approved fogs on my Ex in place of the factory ones, then next to them will either be D2 hyperspots or a 10" Bar, have not really decided yet. This will replace my 4 Hella 500 Halogen lights on the front.
Old Oct 31, 2015 | 05:25 AM
AppocAlexx's Avatar
AppocAlexx
Are the light bars illegal for on road use?
Old May 9, 2020 | 01:45 PM
250SD6oh's Avatar
250SD6oh
how did you wire it to your factory fog lights plugs? I just installed a 20in light bar for my front bumper and want to do the same. But can. Or find anything in regards to the detail of where/which wire to connect to what.
Old May 11, 2020 | 06:08 PM
CalEx4x4's Avatar
CalEx4x4
Don't need no stinkin' light bars. Just a big bumper and a Buttload of wiring. Actually it just added up over the years.
Particularly after I got the heck out of California
Yes, those are Fog lights under the bumper. The Rigid's also have a yellow tinted cover for foggy days.
soundwave
2009 - 2014 F150
Nov 23, 2009 08:24 PM
first_f250
May 11, 2009 02:26 PM
LasVegas F250
Aftermarket Products
20
Nov 21, 2008 01:06 PM
CounterMaker
Sep 1, 2006 03:29 PM
bkvanbek
Jan 4, 2004 11:19 AM
