gem module
Old Oct 28, 2015 | 10:05 AM
syoung1187's Avatar
syoung1187
gem module
I have a 2000 ranger xlt 3.0 4x4. I need to find the art number for the gem module. But its at a shop and i cant get a hold of them at the moment. Is there somewhere i can look up the exact part nnumber from running th vin? Also when i run my vin my truck comes up as 2 x4. But its a 4x4.. will this effect the gem
Old Oct 28, 2015 | 11:50 AM
syoung1187's Avatar
syoung1187
Also the part number on my gem is yl5 z14 b205ea
I can only one with part number yl5t z14 b205ea. So it has a t added to it is this fonna cause an issue
Old Oct 29, 2015 | 08:35 AM
pawpaw's Avatar
pawpaw
Try a PM = Private Message to member Number Dummy, a former Ford parts guy, bet he could tell you what you need to know about the part number.
Old Oct 29, 2015 | 09:13 AM
pawpaw's Avatar
pawpaw
On a second thought, if you have, or can come by the inexpensive ELM scantool, running FORScan, or the like software on the viewing device of your choice, have it scan the vehicle computers/controllers for trouble codes & post All code Number clues, before throwing parts at the problem. If you've already performed a scan, post up All code Numbers you have.
In answer to your tranny/4x4 questions in the 00B40 recall program thread, Yes the GEM, auto tranny & 4X4 are associated, so if your having tranny shifting problems, the GEM belongs on your suspect list, along with the TRS & associated wiring & shift linkage, as you said the tranny had been recently replaced.
On the 4X4 question, the vacuum lines to vacuum operated hubs are common problem items, so if your having 4X4 engagement problems have a look there.
On deciphering the VIN # question, did you use this sites VIN decoder???? It can be accessed by clicking on the "Tools" button drop down in the black bar at the top of this page.
More thoughts for pondering, maybe others reading this thread will chime in.
rockittsled
May 24, 2014 11:48 PM
Hurricane67
Dec 16, 2011 07:13 AM
Snobord28
Mar 7, 2010 10:17 PM
Vampiro
Sep 27, 2006 02:02 PM
brianlr77
1966 - 1977 Early Broncos
Nov 24, 2003 12:07 PM
