1978 - 1996 Big Bronco
Fuel Injection, (starting problem)
Old Aug 15, 2003 | 12:40 AM
DW2455's Avatar
DW2455
okay Thnx, i think i have one i know i have up to a T-30, if not i know where they sell'em. DW
Old Aug 16, 2003 | 10:13 AM
steve83's Avatar
steve83
So exactly when did you do that pressure test? Was it "after it sits overnight or for a long while", or was it "after it cranks the first time"? You need to to make SURE you're testing it WHILE it's exhibiting the fault. I'd put a FP gauge on it one evening, pull one spark plug OUT, insert a compression tester, and put a spark gap tester on that plug's wire (or lay the plug on the block). Arrange the gauges so you can see them WHILE it's cranking, and the next morning, try it. If it cranks right up (coughing from the 1 dead cylinder), you won't learn anything. But if it cranks for a while, look at the gauges and the spark to see what's wrong.
Old Aug 16, 2003 | 10:34 AM
DW2455's Avatar
DW2455
it' got a fresh tune up, that didn't affect it at all, I know i gapped the plugs right, the fuel pressure test were done with the engine barely warm, and i did them according to the haynes book, the fuel pressure dosent leak down right a way, it takes an hour are so, is this about normal, the book say 5psi in 1 min. but as soon as you switch the key on the pressure jumps right back to 40psi. I'm missing something here.
Thnx DW
Old Aug 16, 2003 | 10:48 AM
steve83's Avatar
steve83
I'd forget about the injectors leaking - it doesn't sound like that's your problem. The pressure would fall faster if that was it.
Old Aug 16, 2003 | 10:53 AM
DW2455's Avatar
DW2455
If all the pressure test prove okay, could it be the
TFI mod. on the distr.? an ignition problem isted of fuel? when you switch the key on and it has 40psi then it should fire up, I was kinda under the impresion that the TFI mod. eithr worked or not, Do you know differently? DW
Old Aug 16, 2003 | 12:48 PM
steve83's Avatar
steve83
Yes, it could be anything - that's why I suggested testing everything at once tomorrow morning. If it's not sparking, you'll see it on the gap tester (or spark plug if you do it that way). For any gas engine to run, you need:
air & gasoline (in the proper proportion)
compression
spark (at the right time)
You have to figure out WHICH of those you don't have and WHY it only fails in the morning.
Old Aug 16, 2003 | 02:22 PM
DW2455's Avatar
DW2455
Okay i'll do a cold compresion test and everything else first am i get, if i have the gas prssure onthe rail is there anything else in the injection system that would cause it? DW
Old Aug 16, 2003 | 05:26 PM
steve83's Avatar
steve83
Sure. The injectors may not be opening, or not long enough to get the right mix.
Old Aug 16, 2003 | 05:40 PM
DW2455's Avatar
DW2455
would that be in the ECM? or just bad injectors? The engine run like a top, its just after it sits a long while it acts like and old carb motor that has to spin a few times while you pump the gas peddle to crank it up, once it fires up you shut it off and crank it all day, unless it sits for a long time. but like i said the fuel pressure is there, i can deal with the older motors but i'm struggling to learn this injection stuff! Thnx for any help DW
Old Aug 16, 2003 | 05:52 PM
steve83's Avatar
steve83
I dunno - do the test tomorrow morning and go from there. You should NEVER press the gas pedal while cranking. If the engine is somehow flooded, you can hold the pedal to the floor until you clear the flood, but NEVER pat the pedal or hold it at any mid-throttle position. The engine should start by just turning the key.
Old Aug 16, 2003 | 07:02 PM
DW2455's Avatar
DW2455
i dont do that, but maybe we'll figure out something. DW
Old Aug 17, 2003 | 09:58 PM
carriljc's Avatar
carriljc
However, it starts quick when I do the following:
I crank it over momentarily, then give the gas pedal 2 pumps, then crank again and it fires up right away....
I'm suspecting that it's a worn throttle position sensor; but I'm not sure.
Thought I'd share in case you want to try it.
Old Aug 17, 2003 | 10:07 PM
  #28
DW2455's Avatar
DW2455
I will check it out amung other things. Thnx DW
bulldogcountry1
Oct 19, 2014 08:53 PM
cmdk_93
Dec 30, 2012 07:04 PM
fontime
Jan 30, 2012 06:54 PM
DW2455
Aug 16, 2003 11:54 PM
badboyblue
Modular V8 (4.6L, 5.4L)
Jan 3, 2003 01:21 AM
