Fuel pump issues
Old Oct 27, 2015 | 03:45 PM
Travis12384's Avatar
Travis12384
Fuel pump issues
I have a 94 f150 5.0 bought the truck not running so far the fuel pump was bad and not getting power to the pump unless I ground the #6 pin on the test plug . Trying to figure out why u don't have power at the inertia switch unless u ground the 6 pin
Old Oct 27, 2015 | 05:30 PM
Kemicalburns's Avatar
Kemicalburns
have you replaced the inertia switch?
Old Oct 27, 2015 | 08:48 PM
Travis12384
It wasn't bad had no power at the switch then grounded the #6 pin and had power to the switch and on to the pump I guess my question is if you have to ground the 6 pin to get power to the switch, what causes that? I replaced the relay and still had the same problem
79rngr
1997 - 2003 F150
Jun 25, 2014 10:14 PM
psylynt1
Aug 20, 2013 04:27 PM
Dutter
1983 - 2012 Ranger & B-Series
31
Sep 27, 2011 10:45 PM
speedracer54729
Feb 13, 2008 07:11 AM
kormelistdijetta
Jun 23, 2006 05:39 PM
