A transmission question
Old Oct 23, 2015 | 11:33 AM
Mikes150's Avatar
Mikes150
Transmission flush already?
The dealer recommends me to bring my truck back for a transmission flush. My truck has 54000 miles and I do mild towing.(15 foot Jon boat)(occasional loads of hay,pellets). I was just wondering if anybody knows how to check the tranny fluid because they said it was dark and I want to see for myself before going out and spending 250.00 dollars on a flush. Also do they also pull the pan and replace the filter? I know that some filters in these transmissions can't be replaced.
Thanks!
Old Oct 23, 2015 | 01:00 PM
Izzy351's Avatar
Izzy351
The filter can be replaced, and I personally think that 50k is plenty on the trans fluid (I'll be changing mine then). I'm not sure if they do that or not, but that seems kinda pricey for a fluid change. What year is your truck? I put about 15k per year on mine, so 50k will be about 3 1/2 years on it. I'll probably also do the diffs and the coolant as well. Others will be along to tell you not to bother until 100k, but that's too long for my comfort.
Old Oct 23, 2015 | 01:05 PM
Frantz's Avatar
Frantz
What motor do you have? I don't think it would hurt anything, but I doubt you need it done. For reference the 2014 owners manual states you should change fluid and filter at 150k
Old Oct 23, 2015 | 01:28 PM
Izzy351's Avatar
Izzy351
150k is WAAAAYYY too long IMHO. In my case, that's ~10 years on a fluid. Nope...
Old Oct 23, 2015 | 01:47 PM
David W Jones's Avatar
David W Jones
At 54,000 miles, flushing your transmission fluid is a waste of time and money.
Use Ford's recommendation.
Old Oct 23, 2015 | 08:36 PM
fastback89's Avatar
fastback89
At 15000 miles I pulled the pan and changed the filter to get any break in particles out, My OCD gets the best of me sometimes..
Old Oct 23, 2015 | 08:39 PM
fordman19762003's Avatar
fordman19762003
I have the trans fluid changed every 50k, along with the coolant, plugs and gear lube.
Old Oct 23, 2015 | 10:13 PM
Izzy351's Avatar
Izzy351
Agreed. Anything more than 5 years on fluids is pushing it. 10+ years is ludicrous.
Old Oct 24, 2015 | 11:42 AM
Frantz's Avatar
Frantz
If you are doing lots of towing sure, but most of these trucks are lightly used and and junked at 200k. What's the value of making the transmission last 400k if you aren't using it? waiting 10 years and 150k and then flushing to last another 5 years (typically under lighter duty for the end of life quarter) really isn't going to hurt anything. Further, MOST people aren't even going to be owning the same vehicle for 10 years. So if you plan to trade it in, why waste your money so someone else can limp it along the last few miles? It's just not a practical or economical decision for a majority of users. That may not describe YOU at all, but generally speaking, the intervals are okay to work with.
Old Oct 24, 2015 | 01:00 PM
eriebasin's Avatar
eriebasin
I know I keep posting this video all over this forum; sorry for that; but i think its relevant in many instances. My buddy has a 2013 F150 XLT Ecoboost. He had transmission shifting issues at about 12,000 miles. Turned out to be a bad solenoid like explained in this video. Nonetheless; I think there is good reason to change the fluid per these recommendations.
Old Oct 24, 2015 | 03:58 PM
ford390gashog's Avatar
ford390gashog
Just to clarify, the 6R80 can't be flushed at all. There is no way to flush them. The only fluid that can be changed is the fluid that is in the pan. The thermostat can not be bypassed to do a flush on these. Also Mercon LV turns dark quickly and is not an issue. The dealership knows there is a TSB for the dark fluid in vehicles with LV and they also know you can't do a flush.
I installed the AFE pan on mine which holds 7 quarts over stock. I also upgraded the cooler while I was at it and added a Donaldson filter head and a auxiliary transmission filter.
Old Oct 26, 2015 | 02:22 AM
Mikes150's Avatar
Mikes150
Wow. I will definitely ask my dealer what they do because if they change the filter, only the fluid in the pan and clean the magnet and not all the fluid is drained then I will go to a very reputable shop in my town to do it for half the price.
Old Oct 26, 2015 | 05:17 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
My question actually spawns from this thread: https://www.ford-trucks.com/forums/1...h-already.html.
Since the 2009-2014 trucks (except the 4.6L 2V) all used the same transmission on six different engines, why would a truck equipped with a 3.7L V-6 carrying slightly over half of the tow rating as a truck with a 6.2L V-8 need transmission service as regularly?
Old Oct 26, 2015 | 05:29 AM
tseekins's Avatar
tseekins
Even though ford h as given us a suggested maintenance guide, we all seem to have our own opinions as to what is actually the correct dump cycle for engine oil, transmissions, axles, etc.
Being an old school guy who grew up with 30K mile dump cycles, I'll never exceed 100K miles on the LV fluid.
Old Oct 26, 2015 | 07:15 AM
meborder's Avatar
meborder
They can be flushed, but you need a heated flush machine. The 6r80 is no different than the 5r110 in that regard. To just need to get the trans hot enough to open the thermostat, and use fluid hot enough to keep it open.
Your ford dealer should have the right equipment and knowledge to do the job, if you wish to have it done.
