c6
Old Oct 25, 2015 | 06:57 PM
Markus1966's Avatar
Markus1966
c6
Hi I have a 1988 ford f-250 extended cab 4x4 with a 351 windsor and c6 tranny.I rebuilt the tranny it goes into drive and reverse but when in reverse,it's almost like i'm pushing another truck.I have to rev up the engine and the truck hardly moves.Is there any adjubtments i need to make or did i screw something up.thanks Mark.Update It ended up just being an air lock,jacked up the back wheels and kept shifting parkk reverse neutral drive.Problem solved thank god.
Old Oct 25, 2015 | 10:15 PM
Shadow944795's Avatar
Shadow944795
I'm no expert but that's a sure sign you messed up somewhere or another. Last time I heard of symptoms like that the trans was jamming itself into two different gears at the same time, mind you this was on a Chevy and it had some serious electrical issues causing the problem it being computer based.
Old Oct 26, 2015 | 06:51 PM
My4Fordtrucks's Avatar
My4Fordtrucks
How is it in manual 1? If it also feels the same as reverse there could be something wrong with the "low & reverse clutch".
Ken Blythen
15
Jun 11, 2011 05:03 AM
Ken Blythen
May 1, 2011 09:44 PM
racsan
Mar 22, 2008 06:47 AM
austin123
Mar 2, 2005 04:22 PM
