95 e350 ignition coil location ?
Old Oct 25, 2015 | 03:33 PM
cmh15's Avatar
cmh15
Got a free e350 box truck today, it cranks but wouldn't turn over, I was told by a mechanic to check to ignition coil. My question is, where is the ignitiom coil located? I see the cap and rotor but don't see the coil.
Old Oct 25, 2015 | 04:48 PM
vettex2's Avatar
vettex2
Pull a plug wire and check for spark and then work backward to the coil wire and then the coil
Old Oct 25, 2015 | 08:36 PM
tabijan's Avatar
tabijan
What engine? On the 5.8 it's probably atop the port side valve cover. In any case, follow the center cable from the distributor cap. Or do some Fords have a GM sytle distributor with built-in coil?
Sixto
93 E150 Chateau 5.8 191K miles
Old Oct 26, 2015 | 05:44 AM
JWA's Avatar
JWA
Speak English dammit---"port side" = left/drivers side.
Tabijan must be nautical or aviation based?
Old Oct 26, 2015 | 12:23 PM
cmh15's Avatar
cmh15
Getting sparks and fuel but not cranking.
Pierrel
Mar 25, 2012 11:10 AM
cnice_37
Oct 27, 2011 09:52 AM
hummertires
Dec 31, 2007 12:34 AM
Ihorse
3.8 & 4.2L V6
Jan 27, 2006 04:53 PM
MyTruckOfDeath
May 25, 2003 10:39 PM
