E350 8 lugs 2004 brakes problem conversion
Old Oct 24, 2015 | 09:43 PM
uaintl's Avatar
uaintl
Hi,
Did someone ever tried converting the front brakes on an E-350 2004 to the new style 2008 and up?
I heard that they are much better and that they will fit on the older models.
Also, who sells those ?
Thank you.
Old Oct 24, 2015 | 11:20 PM
tabijan's Avatar
tabijan
Ford?
Have you checked eBay?
Sixto
93 E150 Chateau 5.8 191K miles
Old Oct 24, 2015 | 11:29 PM
uaintl's Avatar
uaintl
Yes i did
Yes i did but i dont know where to even start or how to look for it
Old Oct 25, 2015 | 12:04 AM
tabijan's Avatar
tabijan
Rock Auto has rotors, calipers and brackets with part numbers unique for 08-14. Someone will know if they fit your '04 knuckles which is possible since they use the same ball joints, bearings and tie rods.
Sixto
Old Oct 25, 2015 | 06:43 AM
JWA's Avatar
JWA
Maybe this guy? https://www.ford-trucks.com/forums/1...th-photos.html
The '04 E350 brakes should be adequate for that GVW, the above update was basically intended for the earlier E250's with 8 lug wheels, essentially they become E350 front brakes.
Do keep in mind E150's after 2007 became E250's chassis-wise----previously E150's had 5 lug wheels and a significantly lower GVW and cargo rating.
HTH
Old Oct 26, 2015 | 02:17 PM
uaintl's Avatar
uaintl
Thanks.
But i cant get the link to work
Old Oct 26, 2015 | 02:31 PM
JWA's Avatar
JWA
Try that link or this one again---not sure what happened first time.
dmustang
May 11, 2012 06:26 PM
LAL426
2004 - 2008 F150
47
Jan 16, 2007 09:26 PM
66f100
Feb 21, 2004 08:50 AM
ddgarner
Jan 21, 2004 09:09 PM
