Driver seat- No Power
Oct 25, 2015 | 12:33 PM
Checked all fuses. Has anyone experienced this. Heated seat works. Seat does not work at all!
Oct 25, 2015 | 12:40 PM
Quote:
Originally Posted by
V10-XXL
What functions does it have ?? None of them work ??
Oct 25, 2015 | 12:52 PM
None of them. No buttons work at all.
Oct 25, 2015 | 12:56 PM
find & swap relays. Sorry I do not know where they are.
Oct 25, 2015 | 01:12 PM
V10-XXL
Does your power mirror work?
If not it's a 5 amp fuse.
Oct 26, 2015 | 01:55 PM
Power mirror is fine. Just driver seat and pedal adjustment. Any ideas?
Oct 26, 2015 | 05:35 PM
Behind the driver's seat, plug furthest to the inside. If it is unplugged, the seat power is dead.
It's this one that is unplugged.
Oct 26, 2015 | 08:47 PM
Lay your seat ALL THE WAY back. As far as it will go, then try the controls.
Oct 26, 2015 | 08:53 PM
Nicmike
Yes, I read this a long time ago... Good idea.
Oct 28, 2015 | 08:40 AM
Still not working. Any other ideas???
Oct 28, 2015 | 08:52 AM
V10-XXL
What did you try or look for?
Oct 28, 2015 | 09:11 AM
I checked all fuses, connections under seat and tried the recline the seat back all the way. Maybe a relay?
Oct 28, 2015 | 09:27 AM
V10-XXL
Do you have a DVOM? Check that plug. Either the plug. I think it is the power supply for the under seat unit.
Once the seat works, there is a connector on the pedal adjustments.
With the truck off and key on, can you hear a click of a relay when you press the pedal adjustment switch?
When you start your truck and drive off without a seatbelt, do you get the seatbelt chime?
Oct 28, 2015 | 10:50 AM
the same happened to me. found no bad fuses or relays. then i just replaced the power seat fuse anyways and pushed the rest of the fuses in and it worked seems to be something with the memory seat controls. i dont use it so no the seat works like a charm.
LeeroyDiesel
Sep 17, 2024 03:20 PM
Raptor Rob
2009 - 2014 F150
Sep 16, 2018 07:22 PM
Jmatthews
Electrical Systems/Wiring
Mar 30, 2009 07:24 AM
