Modular V10 (6.8l)
V10 PCV valve
Old Oct 25, 2015 | 10:06 AM
rock2610d's Avatar
rock2610d
V10 PCV valve
So, I bought two pcv valves, one for each of my 2000 excursions.
One I bought at a box auto parts store, the other I bought from Ford.
Both look the same, but they are not the same.
Ford unit I can blow thru both sides easily as well as sucks thru both sides easilly.
The other I cannot blow as easy as the ford unit.
That is the limit of my knowledge of PCV valves.
How do you know which is working like the V10 requires?
Old Oct 25, 2015 | 03:06 PM
fordmerc's Avatar
fordmerc
Use the Ford one. PCV valves are one of the things that I always try to stay with OEM.
Old Oct 26, 2015 | 05:54 AM
JWA's Avatar
JWA
I believe regardless of brand PCV's need to act like check valves---which they are in reality anyway. Blowing through them from the larger end should work, sucking from the smaller end should not. If you're able to effect flow in both directions I'd not use that particular part.
If they rattle when shaken that's not a good sign either......
Make sure to replace the valve cover grommet too.
justmosing
Feb 21, 2018 12:35 PM
Rollie 1
Modular V10 (6.8l)
Nov 12, 2009 08:55 AM
BAJI26
Mar 16, 2008 01:24 PM
one_wicked_element
Oct 16, 2007 12:27 PM
fordmudduk
Modular V10 (6.8l)
Mar 13, 2007 10:44 AM
