Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
09 Escape brake flush
Old Oct 25, 2015 | 08:38 AM
artieb's Avatar
artieb
Hi, I have a 09 Escape and would like to flush the brake fluid and inspect the lines and hoses. I tried to use a Motive power bleeder on my 01 Superduty, with no luck.
Any tips on flushing the Escape? Key on or off, petal position, etc.... Thanks ,Artie
Old Oct 26, 2015 | 07:01 AM
wptski's Avatar
wptski
I've used a Motive pressure bleeder on two other vehicles but not my 2009 Escape yet.
A had a problem with the LR only on a 1990 Buick and had to use a hand vacuum bleeder to get it started. After that, the pressure bleeder worked fine. In fact, a line rusted out on this vehicle and I'm in the process of replacing all the lines right now. What a PITA!
How exactly are you using the Motive pressure bleeder? This is a engine OFF, one person method.
Otherwise, you need a helper to depress/hold the brake pedal with the engine running while you bleed each wheel.
I improved on the Motive but adding quick disconnects to avoid twisting lines right away. There's no manual pressure release on these which it should have. I just bought a 453 or .453" short tubeless valve stem. Drilled a 29/64" hole near the lid, fished in the stem, attached a valve core removal tool and popped it in. Works like a charm
903ASP
Mar 25, 2012 12:52 PM
wheelzzs
Oct 25, 2009 10:02 AM
reamer
17
Nov 16, 2005 06:55 PM
b1rdjx88
May 16, 2000 07:21 PM
b1rdjx88
May 16, 2000 04:29 PM
