i'm now reading the pattern without apllying any resistance on the carrier. some people say you need to read the pattern applying 40 to 50 ftp of tourqe. is that true?
thanks
Yes you should have some resistance to run the pattern. I typically spin the ring gear by hand and hold the pinion flange with the other. You want to get the pattern right and good backlash or you will have noise or burn it up
yes you need to have some resistance when you are printing the pattern. The pinion shims look ok. You should be looking at the spacing ( flank to face ) for pinion shimming, its pretty well centered now you should just need some more back lash.
have .006 of backlash. i decided to stop messing with the shims because i don't think i can get any better. i know it's not perfect but the manuale says it's ok.
