6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Stacks
Old Oct 23, 2015 | 02:02 PM
miakosn895's Avatar
miakosn895
Stacks
I'm looking to put stacks on my truck its a 08 f350 6.4 i saw a post on here with the attached picture can someone please tell me what stacks they are or a similar stack i want them 6" or bigger aussie cut but they have to be flat black
Old Oct 26, 2015 | 08:54 AM
RM2738's Avatar
RM2738
Have you already deleted your DPF & DOC?
Old Oct 27, 2015 | 07:53 PM
miakosn895's Avatar
miakosn895
No I haven't but have everything to do it
Old Oct 27, 2015 | 07:56 PM
miakosn895's Avatar
miakosn895
It's my first time doing stacks and I'm not 100% what I'm doing so far I've installed a h&s mini maxx and did an egr delete I'm putting a 4" downpipe in and then I was going to do the dpf and doc delete if I'm doing anything wrong please correct me
Old Oct 27, 2015 | 08:12 PM
RM2738's Avatar
RM2738
I don't know enough about stack kits to provide an exact recommendation. Once you have the DPF deleted and down pipe in, I imagine it's pretty straight forward bolt up. Of course, there's cutting access through the bed. Are you thinking single stack or dual? I don't know if you could do a dual kit from under the bed due to sufficient room. I'd imagine a single penetration through the bed and then Y over for a dual. Single stack seems very easy in theory. A single pipe with the proper bends should bolt right up and add a tip and you're good to go.
Old Oct 27, 2015 | 08:16 PM
RM2738's Avatar
RM2738
What state are you in? I don't know that I would want stacks on an emission controlled vehicle. That definitely will draw some unneeded attention.
Kliphton
May 10, 2020 07:02 PM
miakosn895
Aftermarket Products
Oct 23, 2015 02:05 PM
miakosn895
Exhaust Systems
Oct 23, 2015 02:04 PM
sawtooth
Sep 21, 2012 10:11 PM
