e4od overheat ?
Old Oct 22, 2015 | 11:11 PM
Mickey Bitsko's Avatar
Mickey Bitsko
e4od overheat ?
I'm hauling a 2000# overhead camper towing 2 atv's on my 92' f-350 hughes performance e4od with aux. trans cooler [12row not recommended by the trans manufacturer to run through radiator], anyway the trans on a 12-15 mi pull in the rockies gets up around 250*+ makes me real nervous , I've cleaned and flushed the cooler and didn't seem excessively dirty but still overheats, seems like it's getting worse with age [seems odd tho ]. Should I jus get the biggest cooler I can find and be done with it ?
Old Oct 23, 2015 | 05:18 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That might help. Using the radiator cooler would help even more.
Old Oct 23, 2015 | 08:07 AM
Lead Head's Avatar
Lead Head
Not sure why tey said not to run it through the radiator. It takes a lot of heat out of the fluid.
Old Oct 23, 2015 | 10:12 AM
Mark Kovalsky
Many people think the ATF runs through the radiator to warm it in cold weather. That is completely untrue.
If there was a transmission failure the trans cooler in the radiator could be full of debris. The best way to deal with this is to replace the radiator. Some radiator shops can clean it out.
Old Oct 23, 2015 | 10:23 AM
dixie460's Avatar
dixie460
Yep... I used to think that too until you explained to me otherwise. Good having you around, thanks for sharing your detailed knowledge.
Old Oct 23, 2015 | 11:35 AM
timbersteel's Avatar
timbersteel
Right on!!
Old Oct 25, 2015 | 11:56 PM
Mickey Bitsko
Thanks for all your suggestions , I ended up ordering a cooler recommended for 22000 # tow capacity what ever that means. It is a couple square inches larger than came with the manufacturers oem but twice as thick and the cooling fins are 1-1/8 " compared to 3/8" . Also going to service trans and change to synthetic ATF to help with cooling. If this doesn't work , I'll put an auxiliary fan dangit ! I WILL win !
Truckman8719
Jul 23, 2018 05:49 PM
toro85
Modular V8 (4.6L, 5.4L)
May 4, 2013 10:02 PM
Crewcab Turbo
May 16, 2012 07:22 AM
linckeil
Sep 12, 2009 11:02 PM
whiteaddiction
Sep 1, 2009 09:28 PM
