My heater core just popped for the 3rd time in 3 months. Help!
Unfortunately most of the parts stores around me only carry the Spectra Premium heater core, which is what has failed me twice. I just ordered a Pro Source made one which looks to be closer to the OEM core I took out. Hopefully that will work. I also bought a new thermostat and rad cap just a cheap insurance against one of those (even though new) being the culprit.
Um, the thermostat is what's blocking flow *into* the radiator and the pump scavanges cold coolant from the bottom of the rad and forces it through the timing case into the engine block.
In a closed loop system there couldn't be pump pressure, it is acting as a circulator.
Pressure forms because the coolant expands when hot, and that pressure should be equal throughout.
There should be a Motorcraft... Yep, Rock:
More Information for MOTORCRAFT HC7
88.79, yes aluminum.
I also recomend using a restrictor from a Fox Mustang in the inlet of the core.
Was the original blown up so bad a competent radiator shop couldn't/wouldn't give it a shot at repair? If not how about a used one & have it tested?
Also, I would not reccomend the Pro Source heater core from Autozone. While the core and end tanks themselves look better made than the spectra, the inlet and outlet pipes are too long. It took way more effort to get them into the heater box than it should have. If this one gives up the ghost, I guess I'll bite the bullet and order the Ford core.
#28
#30
Not sure if I got two duds or what, but I tested pressure tested them both after I pulled them out and they both failed in the same exact spot. It was the two middle rows on the upper tank. First one was a small leak, the second one was a larger one.
holymolie
22
03-29-2011 12:54 AM
