Ranger still having problems starting
Old Oct 21, 2015 | 08:15 AM
Norsegod127's Avatar
Norsegod127
SO ive been after this problem for a while now. When my truck has been sitting for 2 days or its a semi cold morning (35 degrees) the truck has a problem not starting. Ive changed the fuel pump, the starter (my starter was going bad anyways and I thought it could also solve the problem I was having), and the battery was just tested. If I leave my key on Acc for like 10 seconds then try to start, it starts right up or if I just re-start right after the first. Now I am leaning towards this being a fuel pressure problem but im not sure where to start with that... help! lol My mechanic also said that it could be the wire that connect to the battery terminal because they can get corroded.
Old Oct 23, 2015 | 12:47 AM
87 XLT's Avatar
87 XLT
Could be a leaking injector or fuel pressure regulator. Put a gauge on it, does the pressure stay steady with the engine off?
Old Oct 26, 2015 | 11:20 AM
Chris Gathof's Avatar
Chris Gathof
Trailering
im leaning towards a fuel pumo replacement.
Old Oct 28, 2015 | 09:49 AM
spooktn's Avatar
spooktn
what year and engine ,,,, does it have a fuel regulator ????????
Old Oct 28, 2015 | 03:52 PM
Dan Robertson's Avatar
Dan Robertson
My 98 3.0 has been doing that for years. It only builds up about 15 psi at the fuel rail when the key is turned on. I cycle the key on and off, letting it charge 2 or 3 times. Each time I cycle the key, the fuel pressure increases by about 10 to 15 pounds. When it gets to about 45 psi or so it will start and run. After its running, it maintains 60 psi at the rail. The colder it is outside, the more times I have to cycle the key. I was told that the regulator is part of the fuel pump so I'm going to live with it until it gets worse or quits altogether. The old truck has 261,500 miles on it and I just run it as my beater now. I have a tow dolly so when it quits, its not going to be a big deal.
bdfesq
13
Jul 9, 2024 08:47 PM
garymocwi
Jan 24, 2012 08:27 PM
rwdfan
Jun 16, 2011 05:19 PM
jtimcort
Sep 5, 2008 03:12 AM
Aerocook
Aerostar
May 18, 2005 04:28 PM
