Sponsored by: Kumho
Tire pressure
Old Aug 16, 2003 | 12:49 PM
morepower16's Avatar
morepower16
Tire pressure
I've always heard to use the recommend tire pressure but my 91 F150 has 31's on it instead of the 235's. The 235's called for 35 in the front and 41 in the rear according to the door jamb sticker. Should I still follow these pressures or should I use something else since they are bigger tires.
Old Aug 16, 2003 | 01:58 PM
pipefitterpro's Avatar
pipefitterpro
Tire pressure
The pressure given on the tire is almost always way too much. That is the pressure for the max load capacity. I just air them up where they look ok, then draw a line across the tread with a piece of chalk. Drive a little bit and make sure that the whole tread is contacting the ground. You will find that depending on the weight of your truck that the pressure might be as low as 20 lbs. in the rear while the front requires 30-35. Good luck
Andy
Old Aug 16, 2003 | 09:03 PM
MustangGT221's Avatar
MustangGT221
Tire pressure
Do a search under "chalk test" and you'll find a bunch of related threads. The tire/wheel doesn't matter that procedure is still the same.
Old Aug 18, 2003 | 08:20 AM
morepower16
Tire pressure
I did the search with that combination and several others but came up with nothing. Would you mind posting the link or reposting the article.
Thanks
Old Aug 18, 2003 | 02:26 PM
MustangGT221
Tire pressure
Didn't look very hard did ya? I typed in chalk test...and here are the results...
https://www.ford-trucks.com/forums/s...by=&sortorder=
look at those threads, they will tell you the correct method of determining tire pressure...mostly posted by me. This is a FAQ, so the information is there. Doesn't matter what tires or rims you have, as i said above the same procedure applies.
Old Aug 18, 2003 | 02:46 PM
morepower16
Tire pressure
Thanks for the link.
By the way, here is the link from the search I did and even changed some of the keywords but still got stuff like this. What did I do wrong:
https://www.ford-trucks.com/forums/s...der=descending
Old Aug 18, 2003 | 04:16 PM
MustangGT221
Tire pressure
You searched the entire website, I only did a search in this forum.
