Transmission line replacement.
Old Oct 20, 2015 | 07:31 AM
Nathan Cox's Avatar
Nathan Cox
Okay so I'm having problems with the fitting going into the radiator that leads to wherever with transmission fluid. Where can I get a replace ment. Is it as easy as changing a brakeline.
Old Oct 20, 2015 | 11:06 AM
Willz74's Avatar
Willz74
Is it on the hose side or radiator side
Old Oct 20, 2015 | 11:13 AM
Nathan Cox's Avatar
Nathan Cox
Steel line with steel fitting and brass adaptor. That screw into the radiator
Old Oct 20, 2015 | 11:27 AM
Willz74's Avatar
Willz74
Try napa they'll probably be the best place I did a slave cylinder line for my truck from checker and I don't think they have lines long enough
Old Oct 20, 2015 | 11:39 AM
vochy's Avatar
vochy
I had problems getting that fitting new. Your best bet will be a junk yard.
Old Oct 20, 2015 | 11:42 AM
vochy's Avatar
vochy
Or get the fitting off of the broken line, cut the flair off of the new line and re-flair.
Willz74's Avatar
Willz74
Buy one from checker they're not expensive I can't remember the threads on the hose side but the radiator side is 1/4-18 npt
tlambert
Oct 13, 2013 10:39 AM
Ben24
Sep 6, 2013 11:59 AM
Cephus
Aerostar
Jul 7, 2005 12:00 PM
maa139
Mar 11, 2004 04:59 PM
maa139
Mar 4, 2004 06:17 PM
