Rear end click!!
Old Oct 19, 2015 | 09:27 PM
Mikes150's Avatar
Mikes150
Rear end click!!
Hello, I have a 2012 F-150 STX 4x4 with the 5.0 liter. I have noticed that when I put my truck in to reverse and sometimes drive I get a click sound. I jacked up the truck thinking it was the drive shaft that was loose but it wasn't... But I believe it is coming from the rear end. I found a video of the sound on youtube. Does any one else have this issue?
Check it out:
Old Oct 19, 2015 | 09:49 PM
Liam_Harrow's Avatar
Liam_Harrow
I had this same sound on my truck (2012 Eco). I took it to the dealership and they were familiar with the sound. They performed tsb 14-0090 which involved a bolt in the transmission.
Old Oct 21, 2015 | 12:18 AM
ford390gashog's Avatar
ford390gashog
The noise can also be from the yoke to pinion engagement. The two surfaces are not a perfect fit. My 2012 had the issue. The dealership found a tsb which includes replacing the oil slinger and coating the pinion splines in lock tight. So far so good.
Old Oct 21, 2015 | 12:55 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
Mine does it, but it never really bothered me. Before my warranty runs out I may bring it in for this.
Old Oct 21, 2015 | 05:48 AM
Liam_Harrow
Mine even after the tsb will still do it occasionally. It happens so unfrequently that it doesn't bother me either.
Old Oct 21, 2015 | 10:53 AM
FordService's Avatar
FordService
Official Ford Rep
Hello, I have a 2012 F-150 STX 4x4 with the 5.0 liter. I have noticed that when I put my truck in to reverse and sometimes drive I get a click sound...
Hi, gang!
Be sure to let me know if you decide to have your dealerships check out the clicking noise. I'm glad to step in and assist when needed. How many miles are on your trucks?
Crystal
Old Oct 21, 2015 | 11:46 AM
Mikes150's Avatar
Mikes150
54xxx miles
Originally Posted by FordService
Hi, gang!
Crystal
Crystal, my truck has 54,000 miles can the dealership fix it under warranty? I am going in for oil change tomorrow I am going to see if they can put some of that motor craft penetrating oil on there to see if that fixes it.
Old Oct 21, 2015 | 12:33 PM
FordService
Official Ford Rep
Hi Mikes150,
I can't make warranty decisions, but I know your service manager will be happy to answer that for you. Come back and tell us how your appointment goes tomorrow. I'll hang around this thread to see if you need my help.
Crystal
Old Oct 21, 2015 | 06:48 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
I'm at 36,665 right now, still half a year of powertrain warranty left. When I take it back in for my 4x4 issues i'll bring this up also.
Old Oct 21, 2015 | 07:06 PM
Liam_Harrow
Mine is at about 39k. I have an extended warranty until 100k I think.
Old Oct 22, 2015 | 02:48 PM
FordService
Official Ford Rep
Thanks for letting me know, fellas. Once you've had a dealer inspect, give me a shout if you need any assistance.
Crystal
Old Oct 22, 2015 | 09:56 PM
Mikes150's Avatar
Mikes150
Just got done with oil change and the wouldn't look at it because supposedly that's a different part of the shop. So after hunting season I will make an appointment to have it diagnosed. My truck is still under the power train warranty. Does any body know if I have to still pay them to diagnose it?
Thanks.
Old Oct 22, 2015 | 10:54 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
shouldn't!
Old Oct 24, 2015 | 07:07 AM
SBV45's Avatar
SBV45
Thanks.
Really? I would be asking to see the service manager.
I use the Ford Quick Lane at the dealer I use for oil change, tires, etc and if I have any other issue they will pull in the "other part of the shop" to resolve the issue.
Old Oct 26, 2015 | 02:32 AM
Mikes150's Avatar
Mikes150
I am tired of that any time I have an issue that needs a quick browse I always have to make a separate appointment. I have gone to two different dealers in my city. I figured the rear ended click would be part of the multipoint inspection....states under the transmission/drive axle section. I really wish ford corporate could read these but it almost impossible to get a hold of any one higher up on the totem pole.
