Orange intake boots leaking
Old Oct 19, 2015 | 08:23 AM
MP7pt3's Avatar
MP7pt3
#1. ok guys my orange intake boots are leaking. these are the ones under the Intake (spider) going down to the heads. I am also going to do the 6.0 intercooler & trans cooler swap @ the same time. my question is other than new boots & intake inserts from riff raff is there anything else i'm going to need in other words other than the intake am I going to have to remove anything else that I'm going to have to remove that I'm going to need gaskets, seals or oring's for while doing this fix.
#2. any advise or links to the 6.0 intercooler & trans cooler swap would be greatly appreciated. it would be great if I could round up all the parts before hand so is not tohave to stop & make a parts run during the swap.
thanks again all comments & suggestions welcome & appreciated.
Mike
Old Oct 19, 2015 | 09:09 AM
duck fan's Avatar
duck fan
Because racetruck
I would also suggest the clamps with the plenum boots and inserts so you can really clamp down.
Old Oct 19, 2015 | 09:12 AM
MP7pt3's Avatar
MP7pt3
thanks duck fan I forgot to list them but yes they are on my to order list.
Old Oct 19, 2015 | 09:18 AM
HKusp's Avatar
HKusp
Other than what you have listed (with the new clamps) no, you will be good. Here is a link to the 6.0 transmission cooler install.
https://sites.google.com/site/woodnt...attredirects=0
Old Oct 19, 2015 | 09:43 AM
MP7pt3's Avatar
MP7pt3
Thanks HKusp that's better than anything that I had been able to find.
Old Oct 19, 2015 | 10:47 AM
HKusp's Avatar
HKusp
Still looking for the inter cooler write up, can't seem to locate it. Should be very straight forward though. There is a sticky at the top of the main page for the 1999-2003 7.3 that has a list of tech links. In it you will find a link to a guy named wood-n-things, he used to post here. He has a nice group of technical specs and modifications, that's where I got that link for the tranny cooler. Here is a link to his page.
https://sites.google.com/site/woodnt...-350-superduty
Old Oct 19, 2015 | 11:22 AM
MP7pt3's Avatar
MP7pt3
thanks HKusp got it book marked. looks like a lot of good info there on his page.
Old Oct 19, 2015 | 06:32 PM
holeshotwalt's Avatar
holeshotwalt
Be sure to get the correct boots for the intercooler- they're different than stock. Also round up the adapters for the trans cooler lines beforehand- they're not a standard stocked part (but easy to find and order).
The alternative to the one piece adapters is a hodgepodge of heavy fittings...
Sorry I don't have access to my library of links right now!
Old Oct 19, 2015 | 06:46 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
I've got to ask because I didn't know there was a difference. Is there a Benefit to the 6.0 intercooler?
Old Oct 19, 2015 | 06:54 PM
MP7pt3's Avatar
MP7pt3
Suppose to be more efficient & flow better that will help lower EGT.
lupuseven
Dec 5, 2013 12:27 PM
kupaa
Jan 15, 2012 01:08 AM
luvemhot
Jun 23, 2011 09:56 AM
Robert6401
Jun 22, 2009 07:51 AM
