Interior Passenger Door Handle
Old Oct 18, 2015 | 07:01 PM
BBslider001's Avatar
BBslider001
So, anyone got a line on one of these that won't break the first time you pull up on it to open the &*%#$@!!! door? I have replaced two this week, both Dorman, and they SUCK. I have lubed and made sure all the mechanisms are not binding and moving freely. I am thinking these porous plastic China replacements are just cheap. Anyone? Thanks!
Old Oct 18, 2015 | 07:04 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
Your best bet is probably a wrecker Byron.
Old Oct 18, 2015 | 07:08 PM
BBslider001
I was wondering that very thing Nick. I think you are right! I seriously wondered today if I could pay someone to make me a metal one. I have no idea how I would go about it though.
Old Oct 18, 2015 | 07:32 PM
mechmagcn's Avatar
mechmagcn
I have metal ones in my 97 that came out of a 94 F250. Not sure what years will fit.
Old Oct 18, 2015 | 07:36 PM
z31freakify's Avatar
z31freakify
Have you tried the metal ones?
Like this one
Heres my driver side (custom handle) i used a 3/4" metal pipe and has worked great for several years
Old Oct 18, 2015 | 07:39 PM
Action4478's Avatar
Action4478
You need to find out what is wrong inside the door . The first one that broke was a factory handle . Most times its a door out of adjustment ,
pins & bushings , stretched cable ,worn latch or the door it self has cracked around the mounting surface of the handle
Old Oct 18, 2015 | 07:43 PM
97-psd's Avatar
97-psd
Rockauto sells metal ones. I bought one for my driver door and it rocks. When I get a minute I am ordering the other three
Old Oct 18, 2015 | 09:08 PM
BBslider001
Rick, I agree...but looking everything over and lubing the crap out of it, everything seems to be ok. I am guessing the cable is stretched out. I'll look at getting a new one. The mounting surface is really in pretty good shape.
SCORE! I am ordering one tomorrow. Hopefully they still have them.
Old Oct 18, 2015 | 09:15 PM
Action4478's Avatar
Action4478
I have been down this road many times . The reason the handles break in the first place is having to pull on it harder because something else is wrong .
Get a better handle if you think that is the problem .(its not)
Eventually the door won't open from the inside at all . I always question why something goes from working , to not working . Good luck
farmert's Avatar
farmert
The 80-86 trucks came with the metal handles, which are better than the plastic ones, but they still will break as they are just pot metal.
Old Oct 18, 2015 | 09:17 PM
MOOSE_MACHINE
The one in the picture looks like it's from a Walt 80's ford
Old Oct 18, 2015 | 09:24 PM
Action4478's Avatar
Action4478
The older versions of the latch had a wire loop on it that the cable was captive in, the wire loop would easily bend after time making the cable too long. Go ahead & fix the symptom if you like.
Old Oct 18, 2015 | 10:54 PM
BBslider001
Is the cable the only issue if the mounting surface is good or does the latch affect it as well? Meaning should I look at replacing both?
Old Oct 19, 2015 | 07:24 AM
bass-n-fire's Avatar
bass-n-fire
I replaced mine with the metal handles a year ago, after going through about one a week. As I was replacing them I went a head and changed out the hinge pins and bushings and adjusted the nadir pin as well. Haven't replaced a handle since. But I believe I also fixed the route of the problem as well.
Old Oct 19, 2015 | 03:35 PM
Jarrett Campbell's Avatar
Jarrett Campbell
ebay has the metal handles all day long too
