Power stearing pump noise
Old Aug 4, 2003 | 09:04 PM
jimlj's Avatar
jimlj
Last week the power stearing pump bracket broke on my '79 F250. After having to remove the pump to get the pully off to get the broken bracket off to make the repair.................., I now have the low power stearing fluid noise common to alot of Fords. I have filled the pump, and run the stearing back and forth to the stops several times. My question is will the noise go away after I work the air out? Do I need to do something different?
tia
Jim
Old Aug 5, 2003 | 01:15 AM
Torque1st's Avatar
Torque1st
Posting Legend
Did the pump run low on fluid during operation?
Old Aug 5, 2003 | 10:08 AM
dfisher1's Avatar
dfisher1
Jim,
Keep an eye on the fluid level. It will quiet down after awhile.
It shouldn't take more than a day or two.
How long has this been going on?
Make sure the fluid level is correct and you'll be OK.
KingFisher
Old Aug 5, 2003 | 09:02 PM
jimlj's Avatar
jimlj
The pump never ran without fluid. When I took the pump out to replace the bracket, I had to drain the fluid.
The noise only started after I put every thing back together. I have only driven it a few miles, but it seems to be getting better.
Jim
hello113
Jan 6, 2017 01:22 PM
66f250
Aug 16, 2015 11:54 AM
Donald G
New Member Introductions
May 12, 2015 04:21 PM
460 FORD MAN
Aug 3, 2012 11:16 AM
cOpE!
1978 - 1996 Big Bronco
Mar 11, 2010 07:22 PM
