Exhaust and Steering Box Interference
Old Oct 18, 2015 | 03:33 PM
F1 Mike's Avatar
F1 Mike
Another interesting finding from my latest acquisition. While working on the bottom end of the engine I noticed this. Anybody recognize the steering box or have an idea why there is such an interference between the box and the manifold? It hasn't worn completely through the manifold quite yet.
Old Oct 18, 2015 | 03:54 PM
ALBUQ F-1's Avatar
ALBUQ F-1
What do your motor mounts look like?
Old Oct 18, 2015 | 04:54 PM
tinman52's Avatar
tinman52
Welder User
Yup, likely motor/trans mounts are old and squished allowing the engine to settle. Mine doesn't clear by much, but it's not touching.
Old Oct 18, 2015 | 05:24 PM
ALBUQ F-1's Avatar
ALBUQ F-1
That's the wrong nut on the steering box sector shaft, BTW. Should be a sealed nut so oil can't weep out along the threads (only from every other joint).
Old Oct 18, 2015 | 05:53 PM
F1 Mike's Avatar
F1 Mike
The engine will coming out very soon for crankshaft work so that will be the perfect time to check the engine mounts. Everything else on the truck is new so I would be surprised to see old mounts. Of course after seeing the engine snafu I wouldn't rule out a similar error on the engine mounts.
The nut is a nyloc but the thread doesn't engage the nylon insert. What does the correct nut look like?
Old Oct 18, 2015 | 06:43 PM
ALBUQ F-1's Avatar
ALBUQ F-1
It is a regular nut with the outer end welded shut. I've used an acorn nut but it's tight to the exhaust... not what you want. If what you have is working, I wouldn't fret it.
Old Oct 22, 2015 | 11:56 AM
petemcl's Avatar
petemcl
With the engine out it would be a good time to install power steering and headers.
Reds Headers provide good clearance for Toyota power steering box.
Old Oct 22, 2015 | 12:55 PM
F1 Mike's Avatar
F1 Mike
Thanks Pete
I am trying so hard to resist doing anything else that would slow my progress to getting the truck running and on the road. There are endless upgrades that are tempting me right now on the suspension and engine but I MUST resist. I want to get the engine fixed and the truck in paint before next summer so that I can drive it. I will be collecting stuff for projects like the steering for the end of next years driving season.
Old Oct 22, 2015 | 04:37 PM
petemcl's Avatar
petemcl
Thanks Pete
I know the feeling but from experience I hate it when I am taking things apart that I put together previously. The bracket for the Toyota steering box is odd shaped and is much easier to get in without the engine in place. Just saying . . . my 2 cents.
Toyota box is on the left
Old Oct 22, 2015 | 07:50 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Unless you are running really fat, short tires, or parking all the time, I've found no need for PS. It adds a whole bunch of complication to an otherwise simple vehicle. Especially with a flathead.
Old Nov 22, 2015 | 06:30 PM
F1 Mike's Avatar
F1 Mike
Pulled the motor today.
Mount looks pretty bad but not completely pancaked. Is there a source for good mounts, perhaps urethane?
Old Nov 28, 2015 | 12:38 AM
52 4x4's Avatar
52 4x4
NAPA has them (imports) for a '51. Not so easy to find for a '52, though - which I have. - Bob
Old Nov 28, 2015 | 07:16 AM
AXracer's Avatar
AXracer
That looks exactly like the mount pads we used on Gary's truck got them from Speedway.
Universal Bolt-Through Engine Mount Cushion Kit
I'd also expect Classic Haulers www.classichaulers.com would have them.
Old Nov 28, 2015 | 10:40 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Dennis Carpenter makes them, sold by C&G and others, but everyone seems to be out of stock on the upper piece.
Engine Mount | Dennis Carpenter Ford Restoration Parts
Old Nov 28, 2015 | 12:16 PM
F1 Mike's Avatar
F1 Mike
Speedway Motors shows them in stock for $19.99 a pair. I need to order engines gaskets so I'll tack the mounts on to the order. Thanks everybody.
