I need a vacuum hose diagram of a
1978 F-150 Ranger, 351M, & stock A/C (big box under hood), with 2WD Manual trans 4-speed OD.
If anyone has one it'd be appreciated.
This truck has been well cared for through the years. & is 93% unmolested.
Got some things added fog lights, anti-rust coating, & trailer wiring early on.
But is all stock. So I know that it's got the parts it's supposed to have.
So if anyone has a vacuum hose emissions diagram for my truck, it'd be great.
1978
F-150 Ranger
351M
(Spaned 78-83, called the false top loader because
it had gears loaded thru top, but had side shift linkage/shifters.)
1978 F-150 Ranger 351M stock A/C (big box under hood) 2WD Manual trans 3-speed w/OD
(new type for 78-79 little rare, called the false top loader because it had gears loaded thru top, but had side shift linkage/shifters.)
RUG SR-OD Single Rail 4 Speed Overdrive available in 1978/83 F100/150 2WD
The problem with vacuum charts is that there's about a hundred different setups and each had multiple pages. These aren't 1 page things you're asking for. I'd look into buying your shop manuals on CD from amazon. Will run you about $35, usually the first thing I recommend buying. If you do some searches on here you'll find some charts but I found that its never the one that I need so I paid the $35.
I had the same problem as BigMighty. I bought the manuals on CD and they are great, but I can't locate a vacuum diagram in them. I have the Motor, Body/Chassis/Electrical and Predelivery manuals.
