Leaky m5od.
Old Oct 17, 2015 | 03:16 PM
Jarryd's Avatar
Jarryd
Leaky m5od.
What are the common places to check? Bottom side of my tranny has fluid all over it.
Old Oct 17, 2015 | 03:30 PM
Willz74's Avatar
Willz74
The back part comes off probably at the separation
Old Oct 17, 2015 | 03:48 PM
85e150's Avatar
85e150
The most common leak on those is the rubber or plastic plugs on the top cover for the shift rails.
Rear seal I suppose would be next.
You should have a removable floor panel. You can inspect the top of the trans, replace the plugs up there, take the top off the box and service the shifter and shift forks as well.
Link in post 4 tells the tale. I thought there was one with pictures but once you get that cover off, it will be very clear.
https://www.ford-trucks.com/forums/1...over-leak.html
Good luck with it.
Old Oct 17, 2015 | 03:52 PM
Jarryd's Avatar
Jarryd
I'll pull the cover and check it out when I get a chance.
kng
1983 - 2012 Ranger & B-Series
Nov 12, 2009 09:09 AM
Heavenword1
Jan 12, 2007 10:16 AM
djimmy31
May 29, 2006 01:27 PM
phoneman71
Sep 28, 2004 01:41 PM
nightme_02
Apr 24, 2004 10:11 PM
