AOD column shifter slop! Help a brotha out!
Old Aug 4, 2003 | 06:35 PM
Hit Man X's Avatar
Hit Man X
Angry AOD column shifter slop! Help a brotha out!
Okay, my column shifter has a considerable amount of slop in it. For instance it is pretty difficult to tell the difference between OD and D and is very annoying as I don't used OD for city driving.
Any pointers on how to tighten up this shifter?
Thanks!
Old Aug 4, 2003 | 06:44 PM
tripndrag's Avatar
tripndrag
This can be adjusted under the truck on the shift linkage. My truck did this for 16 years and I never thought of fixing it when I was working on the truck. When I put my new tranny in after the test drive I was determined to fix it. When I was in drive it would move so the orange slider moved off the D so it looked like it wasn't in drive. I had my wife sit in the seat and shift it into D, I then took the shift linkage bolts loose on the shaft that comes down from the firewall and moved it till she said the D was all orange. It has been perfect ever since. It took a couple times of moving it to park and then back to D to get it right.
Old Aug 4, 2003 | 06:48 PM
90f150moneypit's Avatar
90f150moneypit
I hope this helps!
Old Aug 4, 2003 | 06:49 PM
Hit Man X's Avatar
Hit Man X
That slider is long broken on my truck...I mean the feel of putting it in gear is sloppy.
Old Aug 4, 2003 | 08:00 PM
steve83's Avatar
steve83
What year truck is this?
Old Aug 4, 2003 | 10:42 PM
Hit Man X's Avatar
Hit Man X
It's an '88
Old Aug 4, 2003 | 10:53 PM
steve83's Avatar
steve83
Look for loose fasteners or worn plastic bushings in the linkage at the firewall and going down to the transmission.
Old Aug 4, 2003 | 11:11 PM
Hit Man X's Avatar
Hit Man X
I will check them both. If some of my rubber is bad, where would I go about picking up the replacment pieces?
