2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
2011 Limited Expy
Old Oct 14, 2015 | 10:03 PM
pablocruz69's Avatar
pablocruz69
2011 Limited Expy
I recently bought a 2011 Expedition Limited, it has 75k miles on it. The other night my wife was driving home and the engine died. When I tried to start the engine it would start for a second and then shut off, but when I pressed on the accelerator the engine would start. Once I let off of the gas it would die. I read on another forum where someone disconnected the MAF, I tried it and it worked. I immediately plugged it back in and was able to drive it home. I bought a new MAF and replaced it. Prior to replacing it, I noticed while parked and idling I noticed the engine would rev up from 1000 RMP to 2000 to 2500 RPM and then it would settle back down to 1000. Could this have been a vacuum leak or a true MAF issue? I called the dealer, but they basically told me that because I didn't purchase the extended warranty there was nothing they could/would do for me. Thank you in advance for any help or advise you may be able to give....On a side note I drove it all day after replacing the MAF and have not had any issues.
Old Oct 15, 2015 | 08:24 AM
FordService's Avatar
FordService
Official Ford Rep
Originally Posted by pablocruz69
...Could this have been a vacuum leak or a true MAF issue? I called the dealer, but they basically told me that because I didn't purchase the extended warranty there was nothing they could/would do for me....
Hi pablocruz69,
Congrats on the Expedition! Just to clarify, is your extended warranty from Ford or is it aftermarket? Let me know if you decide to have your local Ford Dealership diagnose this for you; once they've taken a look, I'll be able to research some options to assist.
Crystal
Old Oct 15, 2015 | 08:55 PM
pablocruz69
The dealer is going to look at it. I'll update you once I get the diagnosis.
haviland
Aug 31, 2015 08:36 PM
pech33
Jul 12, 2015 10:10 AM
Cheeshead17
Sep 7, 2007 09:42 AM
nckracer
Jan 24, 2006 09:45 PM
