Power Steering Gear Input Leak
Old Oct 14, 2015 | 04:49 PM
jonmammenga's Avatar
jonmammenga
I finally got my truck up and running only to find that input seal to the power steering gear is leaking. Any suggestions if I can replace just the input seal easily or do I have to replace/rebuild the entire assembly? The unit functions just fine but input seal is leaking pretty good. If I need to purchase a new/rebuilt one....where should I get. I can get a reman'd one from Oreilly or AutoZone for $200 or rebuild mine for same cost. Or Redhead steering gear one for $375.
I would really like to just replace the input seal if possible but I am not a steering gear expert.
Old Oct 14, 2015 | 06:42 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Can be done with the gear box on the truck, seals are available. Read thru here, there is a walk thru of the replacement of each seal. Input and out put.
https://www.ford-trucks.com/forums/1...then-some.html
Old Oct 15, 2015 | 10:54 AM
jonmammenga
Thank you very much. I got the seal kit and will give it a shot tonight!
Old Oct 15, 2015 | 07:00 PM
77&79F250's Avatar
77&79F250
No problem, thanks to the other folks on here that provided all the info. How about doing a tech thread with pics on how it really goes.
Old Oct 15, 2015 | 08:22 PM
jonmammenga
I just walked in from doing the job. Pretty dang easy and fixed the leak. I have another 1979 F150 4x4 that I am gonna do it to as well. I will document that one......it is my hunting truck I picked up for 1000 bucks. Just needed a little TLC. My black 79 I just restored was the was one I just fixed. Would have been nicer pics.
ExBailBonds
Aug 1, 2009 04:02 PM
smbikes
May 15, 2009 09:40 PM
Zerojunk
Jun 8, 2007 10:35 AM
Gib
Jan 20, 2000 08:40 AM
