need a power steering pump pulley
Old Oct 13, 2015 | 10:30 PM
seventy2ndst's Avatar
seventy2ndst
Hi everyone
I am new to the site, but I am looking for a DAOR-B power steering pulley. I have a 1979 f150 4x4 lariat and a bent pulley. no one seems to have a replacement... any help?
Old Oct 13, 2015 | 11:20 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by seventy2ndst
Hi everyone
I am new to the site, but I am looking for a D0AR-B power steering pulley. I have a 1979 f150 4x4 lariat and a bent pulley. no one seems to have a replacement... any help?
Welcome to FTE
D9TZ-3A733-A (replaced C9TZ-3A733-D) .. P/S Pulley / Marked: D0AR-B or D0AR-3D673-B / Obsolete
1973/77 F100/150 302 / 1973/77 F100/350 460 without A/C / 1977 F100/250 2WD & F350 351M/400 / 1979 F150/350 351M/400 4WD & Bronco.
1973/74 LTD 351C/400 / 1975/76 LTD 351M/400 with Ford P/S pump / 1976/77 LTD 302/351M/400 without Hydro-Boost / 1977 Thunderbird/Cougar 351M/400.
No Ford dealer or obsolete parts vendor has any.
C9TZ-3A733-D =
MUSTANG SERVICE CENTER in North Hollywood CA has 1 = 818-765-9266.
Old Oct 14, 2015 | 01:40 PM
burnthelight88's Avatar
burnthelight88
Judging from just the part # I can't tell which type of power steering pump you have, but some of them were used from the mid-late 70's into the early-mid 90's. I'd hit a junkyard with your old one and start looking. That's a pretty easy junkyard pull.
Old Oct 14, 2015 | 01:55 PM
NumberDummy
It does not make any difference what type of P/S pump the OP has, as it all depends on the application for the pulley.
OP needs a pulley marked D0AR-B which was used with the Ford/Thompson P/S pump used thru 1977 and the Ford C-II P/S pump introduced in 1978.
Ford/Thompson pump has a steel reservoir, the P/S pressure hose threads onto the pump.
Ford C-II P/S pump has a plastic reservoir, the P/S pressure hose has a straight tube with an o-ring at the pump end. It connects to the pump using a qwik connect fitting.
Old Oct 19, 2015 | 10:19 PM
seventy2ndst
Thanks for the responses...
I called that mustang shop in CA and they said they had it but I just got it and it has "DOAR-B1" on it...
Looks like the same diameter pulley but the offset doesn't look the same. Any idea of the difference?
Also was given a DOAR-A... Its slightly bigger but would probably work but won't give me the same rpm. Anyone ever try to use the "A" on their truck?
Thanks
Old Oct 19, 2015 | 10:25 PM
grinnergetter's Avatar
grinnergetter
Let me check tomorrow, I'm almost positive I have several of those.
Old Oct 19, 2015 | 11:22 PM
NumberDummy
Thanks
D0AR-B1 is the same as D0AR-B // D0AR-A or D0AR-3D673-A = D0AZ-3A733-A Applications:
Old Oct 20, 2015 | 08:19 PM
grinnergetter
I have 2 if necessary.
Old Nov 18, 2015 | 03:38 PM
seventy2ndst
thanks guys... I found one. it looks like I have a valve stuck open. no compression on #4. can the valve cover/head be pulled without pulling the engine out? AC looks like it is going to make that difficult
Old Nov 18, 2015 | 05:50 PM
Blue and White's Avatar
Blue and White
The valve cover and head should be removable in chassis. For the head, in general you unbolt the AC compressor and move it out of the way without disconnecting the refrigerant lines. That way no contamination in the AC and no need to re-charge.
With a suspected stuck valve, best to pull the valve cover first and have a look see. Turn the engine over by hand and watch the valve action. If it is stuck, likely there is a bent pushrod also. If it sat for a while, one of the valves may have rusted and stuck in a guide. Best repair if that's the case is to get the head rebuilt at a good machine shop. They can check/correct condition of all the valves & guides. I had to do that once on a Dodge 225 6 cylinder in a boat.
1974F1004x4
Nov 10, 2019 08:24 PM
Bulldog187th
Aug 15, 2017 11:29 AM
FordF100man
WTB - Parts & other
Aug 28, 2015 08:41 PM
deathmobile2
Nov 17, 2012 02:48 AM
plsix
Sep 13, 2012 03:10 PM
