Lincoln Sag Conversion - Need Part Number Decoding
Old Nov 15, 2012 | 03:33 PM
deathmobile2's Avatar
deathmobile2
Can anyone tell me if the following is associated with a 1978-79 Lincoln Mark V with a 400:
- D9BC-3A732-AA Power Steering Pump Bracket - Just purchased
- D9TA-3C511-AA Power Steering Pump Adjustment Bracket - may purchase if it is the right one
Old Nov 15, 2012 | 06:19 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Marked with ID number: D9BC-3A732-AA = Ford part number: D9BZ-3A732-A Power Steering Pump Bracket
Marked with ID number: D9TA-3C511-AA = Ford part number: D9TZ-3C511-A Power Steering Pump Adjustment Bracket
D9BZ-3A732-A .. 1978/79 Fairmont/Zephyr 200 I-6 ~ Use with Saginaw P/S pump.
D9TZ-3C511-A .. 1979 E100/150 302 ~ Use with Saginaw P/S pump.
1973/79 L/M Parts Catalog is available on a CD from hipoparts.com
Old Nov 16, 2012 | 07:30 AM
deathmobile2
I have to disagree
There must be other uses for the same part number - they are coming off of 335 Series engines that I have seen for myself............
Old Nov 16, 2012 | 07:38 AM
J ballan's Avatar
J ballan
Check out WILD HORSES 4X4 Off-Road Bronco Parts and Accessories that's where I picked up my Saginaw pump bracket for my 400. Worked really good and really cleans up the engine compartment.
Old Nov 16, 2012 | 07:53 AM
deathmobile2
WH is fine, but does not support AC trucks - I want to retain the factory AC and these components come out off of a 400 engine with AC.
Old Nov 16, 2012 | 09:14 AM
NumberDummy
You can disagree if you wish, but I looked up the ID engineering numbers you posted in the Ford Master Cross Reference Catalog, crossed them to Ford part numbers.
Then looked the part numbers up in the 1973/79: Ford, L/M Passenger Car and Light Truck Parts Catalogs, listed the applications.
Old Nov 16, 2012 | 09:40 AM
deathmobile2
Do you happen to have the schematic for the power steering pump mounting brackets for a 1978 Lincoln Mark V?
At the end of the day, if the stuff fits and works, then I will be happy.
Old Nov 17, 2012 | 02:48 AM
NumberDummy
I have the 1973/79 L/M parts catalog, have the schematic, but my catalog is on microfiche. AFAIK, no member of FTE has the CD version available from hipoparts.com.
Bulldog187th
Aug 15, 2017 11:29 AM
steve340
Sep 15, 2015 02:19 AM
P38fighter
Aug 6, 2015 11:37 AM
Zues1
20
Jan 12, 2013 07:01 PM
9d4
Apr 25, 2008 11:59 PM
