Starting issues
Old Oct 13, 2015 | 09:17 PM
Mike Jahnke's Avatar
Mike Jahnke
Starting issues
Recently came to own an 81 F150 300cid. Previous owner had stated the truck was runout of coolant and overheated. Although his daughter kept adding water to keep from overheating too much. Then she also ran it out of gas. Truck then sat for a couple weeks before he even attempted to start it. Now it just cranks and won't fire.
Things I've checked;
Battery, charged fully
Spark plugs, not a strong my spark but still has a slight bluish color
Fuel filter, new
Carb, no obvious signs of sticky jets (fuel sprays normal)
Any help would be greatly appreciated.
Old Oct 14, 2015 | 01:42 AM
FordFETruck's Avatar
FordFETruck
Have you tried seeing if it will fire off of some carburetor spray down the venturi? does it have enough compression to start?
Old Nov 13, 2015 | 03:55 PM
Mike Jahnke
Will not fire with ether or fuel sprayed into carb. How much compression should it have under normal starting/operating conditions.
Old Nov 13, 2015 | 04:05 PM
FordFETruck
I've seen engines with as low as 100 PSI in all cylinders still start and run fine.
Old Nov 13, 2015 | 04:09 PM
roadrash63's Avatar
roadrash63
I'm betting on a new ignition coil.
Old Nov 13, 2015 | 04:18 PM
Mike Jahnke
Is there way to test the ignition coil? If so, what test and what kind of reading should I be looking for?
Old Nov 13, 2015 | 04:52 PM
roadrash63's Avatar
roadrash63
You need a multimeter
Sorry I don't have the specs .
I usually have one laying around that I swap out.
Old Nov 13, 2015 | 05:02 PM
FordFETruck
Take a multimeter, put it on the OHMS scale. To test primary resistance, touch red and black to the positive and negative terminals on the coil. It should be around 1.3-1.5 OHMS. To test secondary, take one of the leads and put it in the center (coil output) terminal, and hold the other on one of the other terminals. Secondary resistance should read around 8K OHMS. As far as testing the output of the coil, no idea how with this method. The only way I know how to test coil output is with a Sun engine diagnostics machine, which very few people have.
Old Nov 13, 2015 | 07:21 PM
Mike Jahnke
Alright swapped out a new ignition coil. Same effect, cranks but no start. Buddy is brining over a compression tester tomorrow, to check that.
mountzionryan
Oct 4, 2016 07:23 AM
seanandrews1
Jun 16, 2013 11:55 PM
fristford
Feb 14, 2013 12:00 PM
Johnny Staff
Feb 27, 2006 04:00 PM
levi11
17
Feb 25, 2004 07:49 PM
