Front Coilover system for Mustang II
I have a 55 F-100 with a Mustang II frontend under it and a 429 engine. I have replaced the normal 375 coil springs with the heavier 425 coil springs, but it is still much too low.
I am considering a set of QA-1 Coilover units, but with the length of the coilover springs I am not sure this will solve my problem. I was looking at the 1701-1900 springs with the shocks. Has anyone any experience with this setup or a similar problem?
Eaton Detroit spring has a good chart for stock style springs, It gives loaded spring heights and they will exchange springs if you get wrong one. As far as the coilover conversion , that would work too but you will probably need new lower control arms. Qa1 has springs up to 700 lbs for the conversion setup.
At least the QA1s will be a quality shock upgrade (single, double adjustables?), should be valving matched to the springs you use, don't go overboard on spring choice tho too heavy a spring will be as bad/worse than too light: ride hard/harsh, throw off handling, get the right ones. Coilover springs are inexpensive. Best thing to do is find a certified scale, truck stops, scrap yards, etc. Get two weights: one with the entire truck on the scale (gross weight), second with only the front wheels on the scale platform (front axle weight), driver included. (You can subtract the front axle weight from the gross weight to get the rear axle weight). Give the weights to QA1 for their spring recommendation.
If the front is a chinese clone MII the front springs are likely to not be the spec strength, sagged badly due to poor quality steel, not properly heat treated.
japrine
16
01-30-2024 03:25 PM
351Cleveland C4
07-11-2014 01:54 PM
Quiff_boy_Elvis
16
09-13-2009 06:01 PM
ABA
13
01-10-2007 10:33 AM
