MAF Sensor = MAP Sensor?????
Old Oct 12, 2015 | 12:25 PM
seagiant's Avatar
seagiant
Hi,
Ran the codes on my 1989 F-150 4.9 EFI and got a code #66!
That is "MAF Circuit below minimum voltage"
However I understand from research that my truck only has a MAP Sensor???
Trying to figure this out and fix to clear code, anyone have any ideas on this???
Thanks!
Old Oct 12, 2015 | 12:37 PM
Willz74's Avatar
Willz74
Maybe you should tell the computer it's MAP
Maybe you should try another source for codes it might be for a different year
Old Oct 12, 2015 | 12:57 PM
rla2005's Avatar
rla2005
Correct Code 66 Definition: TOT sensor output was less than Self-Test minimum value of 0.15 volts. TOT= Transmission Oil Temperature.
That can be triggered by not warming up the engine and transmission before running the KOEO tests and stored code (CM) display.
Old Oct 12, 2015 | 01:09 PM
seagiant's Avatar
seagiant
Hi,
Hmmm...my code map index says #66 is low voltage on MAF Sensor???
Maybe as mentioned I have wrong index but it is suppose to be for OBD-1 computer???
Thanks Gentlemen that should mean I'm good!
Will look for another index!
Looks like #66 has TWO meanings!
http://www.troublecodes.net/ford/
Old Oct 12, 2015 | 06:29 PM
Conanski's Avatar
Conanski
What is your code reference? An '89 truck does not even have a MAF sensor so it can't be that. Note that the reference book for an OBD1 code reader like the Equus 3145 has two different sections... one for cars and another for trucks.
Old Oct 13, 2015 | 08:13 PM
seagiant's Avatar
seagiant
Hi,
In the Equus manual I downloaded it says (trucks) #66 MAF Sensor below voltage???
Admittedly I don't have the reader just a jumper wire and count the flashes on the "check engine" light!
Thanks!
Old Oct 26, 2015 | 06:39 PM
Logan Lucas's Avatar
Logan Lucas
watched vid on you tube ford techs clearin code from pcm dis connect -bat cover terminal connect jumper from -cable to pos side for 10 min this will reset pcm upon start up allow to idle 10-15 min test drive make sure istuments r off before turning key to on pos. also shift at proper rpms your pcm is relearning its values
jmartinez44
Modular V8 (4.6L, 5.4L)
Feb 2, 2016 07:58 AM
mtntop1
Apr 8, 2009 10:22 AM
Fordenthusiasts
Aug 27, 2008 09:30 PM
fixingbus
1983 - 2012 Ranger & B-Series
Mar 28, 2008 06:05 AM
murphf-150
Nov 26, 2006 10:54 AM
