1989 f250 shift problem
Old Oct 11, 2015 | 11:05 AM
AndrewS89f250's Avatar
AndrewS89f250
I have a 1989 ford f250 5.0l v8. Tag on transmission says E9TA BA, which what i read was the M5R2. I can pull out in 1st gear, and when i go to shift into 2nd gear it grinds at first but then goes into gear, and i can't get it in third gear at all. New clutch kit, slave cylinder, master cylinder line, shifter repair kit, and pedal assembly. i'm told i need a new transmission. just wanted to get others opinions. is there another solution? what is causing this? i read the m5r2 leaks fluid. any input would be greatly appreciated. And if a transmission is needed, where can i get an m5r2 cheap? my last resort is the local u-pull-it, as it is unsafe to pull a transmission as the car are securely lifted. Thanks!
Old Oct 11, 2015 | 09:54 PM
whisler's Avatar
whisler
2 wheel drive or 4x4?
Old Oct 12, 2015 | 05:45 AM
AndrewS89f250
It is 4x4.
Old Oct 12, 2015 | 08:39 AM
whisler's Avatar
whisler
Post your location and check your visitor messages.
amccabe1
Nov 10, 2017 10:50 AM
gwshaw
1983 - 2012 Ranger & B-Series
Dec 11, 2016 09:42 AM
Lex Dayton
Apr 6, 2012 08:01 PM
zach_barrow
Feb 4, 2008 09:10 PM
stanleyadams
Mar 4, 2001 06:30 PM
