Cab seals on 79 SuperCab
Old Oct 10, 2015 | 06:54 PM
79super150's Avatar
79super150
I need to replace door seals on my supercab and was considering doing the rest of the cab/windows at the same time. The kit from LMC is only $150 before shipping for all of the seals where just the door seals are $65. I'm just worried about dealing with all of that glass and breaking something because I havent done it before. What would a shop usually charge for all of the window seals including the rear split window? and is this a project I should consider doing myself?
Old Oct 10, 2015 | 08:28 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I got my window seal kit from Jeffs Bronco Graveyard (great product) and replaced both inner and outer anti rattle/upper and back and division bar seals with the glass still installed. Wing seal was fine. Does you SC have tilt out/opening windows?
Just removed the bolt at the bottom of the fwd track, below the regulator. To leave the door glass installed.
If you take it to a place that does it all the time, they should have the experience, tools, tips and tricks and you should get a guarantee on breakage.
Bronco, Ford Trucks & Crew Cab Window Weatherstripping Kit-Broncograveyard.com
Old Oct 11, 2015 | 12:59 PM
79super150's Avatar
79super150
Thank you for the info. I do not have the opening rear window on my supercab. None of the fixed glass is leaking but it is starting to crack so I was considering doing it all at the same time as the doors and windows
Old Oct 11, 2015 | 01:00 PM
79super150's Avatar
79super150
Who manufactures good replacement door panels? Ive heard the LMC ones are super cheap and don't hold up
Old Oct 11, 2015 | 09:05 PM
77&79F250's Avatar
77&79F250
Dennis carpenter has a great rep. Ck out the vendor list. https://www.ford-trucks.com/forums/1...l#post14955940
Old Oct 12, 2015 | 12:48 PM
scottscott's Avatar
scottscott
Thread on door weatherstripping: https://www.ford-trucks.com/forums/1...-striping.html
Coltin1992
Apr 15, 2016 07:00 PM
Doubleclutch
15
Jul 21, 2015 11:21 AM
Intimnasc
May 25, 2012 12:44 PM
tastyklair
Oct 25, 2007 09:59 PM
TheMachfather
Jan 25, 2004 12:24 PM
