2003 expedition Eddie bauer
Old Oct 10, 2015 | 05:08 PM
Trancour's Avatar
Trancour
Just changed transfer case shift motor and no dash indicator lights and four wheel drive does not work. What to look at next?
Old Oct 10, 2015 | 10:19 PM
Skauber's Avatar
Skauber
Could be a fuse (don't have fuse diagram for '03 so can't tell you which), or it could simply be bad wiring or a bad selector switch.
Old Oct 11, 2015 | 09:54 AM
alloro's Avatar
alloro
Check fuse #115. (30-amp)
Old Oct 11, 2015 | 12:42 PM
Trancour's Avatar
Trancour
Fuse is good. But I do have 2 dead fuses in box. Are these fuse box's known for failure?
Old Oct 11, 2015 | 01:16 PM
Trancour's Avatar
Trancour
Fuses for 4 wd.are all good but do have 2 dead fuses. Are these fuse boxes notorious for failure? When should power be found on shift motor?
Old Oct 11, 2015 | 02:47 PM
alloro's Avatar
alloro
What numbers are the dead fuses?
h20ford
Dec 9, 2018 12:27 AM
h20ford
Dec 9, 2018 12:25 AM
Garnet
Dec 31, 2011 08:19 PM
jfboy
Sep 18, 2007 09:51 AM
steaks73
May 29, 2003 11:11 PM
