2011 Carrier Bearings failure, again.
Old 03-29-2016, 03:29 PM
BigDfromTN's Avatar
BigDfromTN
BigDfromTN is offline
UPDATE...
Just took this truck to dealer again for oil change and some other items.
One being rear diff noise. Tech advises its the pinion bearings now. They plan to replace them, and the Carrier bearings (AGAIN) as a precaution.
I asked about the wheel bearings also since they would have been contaminated by the same diff grease as the other two sets... Waiting to hear back.
I did ask Tech about rear diff grounding and he did not know of any or that any of them had it since there were no electronics in the rear diff. ????
SOMETHING IS NOT RIGHT!!!
Old 03-29-2016, 04:26 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
The grounding issue in some large trucks is a result of static electricity buildup on long hauls and associated arcing causing pitting of bearing surfaces and premature failure. Kind of a long shot here, probably something else going on.
Old 03-31-2016, 11:18 AM
BigDfromTN's Avatar
BigDfromTN
Further update.
Picked up truck this AM. Tech replaced Pinion Bearings, Carrier Bearings, and Wheel Bearings under parts warranty.
I took a look at all the bearings and the wheel bearings did show some wear expected with 97K miles. Pinion bearings showed a little more wear. The worst wear was in the Carrier bearings AGAIN.
I asked the tech a couple of general questions such as "What lash did you set this up at?" He was spot on with .08-.012. Also asked "What could be causing this? Mis alignment from factory, or what?" Tech said he looked at and inspected it for alignment (some how) and the rear diff tubes did not show bent up, down, fwd, or back.
Im not sure what is going on but we will see...
Old 04-01-2016, 08:13 PM
Papa Tiger's Avatar
Papa Tiger
Papa Tiger is offline
Temporarily Deactivated
Received 3,432 Likes on 2,347 Posts
Usually consistant bearing failure results from either improper installation, too tight, which also wrecks the ring gear or not cleaning the housing of steel chips. UR at the point where a different axle/differential might be wisest choice. These promlems usually begin with the pinion depth being set wrong which magnifies by trying to make up for it at differential carrier instal and usually ends up noisy but not the bearings busted up like total bearing failure would do.
Old 04-04-2016, 10:03 AM
BigDfromTN's Avatar
BigDfromTN
Thanks for the reply.
Im told they totally flushed the rear diff internals, axle tubes and all. They did replace all the bearings as I inspected them after the fact.
We will see.
kawasaki150hp
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
12-11-2018 09:52 AM
78 Ranger
1997 - 2003 F150
08-12-2012 08:59 AM
lemonshindig
06-23-2012 11:58 PM
RobertJohn
08-10-2005 01:23 AM
Quick Reply: 2011 Carrier Bearings failure, again.
