wiring problems?
Old Aug 4, 2003 | 01:03 PM
okiebronco's Avatar
okiebronco
wiring problems?
my 79 f250 has recently started doing something strange. when i have my headlights on the right turn signal arrow in the cluster glows a light green. i turn my right signal on and the glowing arrow goes away and it flashes bright then goes pitch black then bright then pitch black ect like it should. im not sure when it started happening but sometime after i noticed this problem i also noticed that at times the truck starts slowly. i mean it turns over hesitantly like a low battery or timing too far advanced. it only turns over slowly when its warm and its always started and never left me stranded but i THINK these 2 problems may be connected unless its just heat from the exhaust soaking into the starter. what are your ideas on what to look for to fix my dash predicament? all my lights light up bright as they should also
Old Aug 4, 2003 | 01:24 PM
Mil1ion's Avatar
Mil1ion
wiring problems?
Starter :
Does it do this when it's cold ?
I would suggest disconnecting the battery and cleaning all the connections,including the voltage regulator connections & mounting area.
Lights:
I would suggest that you have a minor short in one of the light harnesses or bulb sockets on the right side of the truck.
Old Aug 4, 2003 | 01:29 PM
okiebronco's Avatar
okiebronco
wiring problems?
my terminals are clean but the starter only drags when its warm... driving for a half hour or more in 110 degree heat.
as far as lights i just need to check the sockets right? the light doesnt get brighter or dimmer from wiggling wires. could it be my turn signal switch itself?
Old Aug 4, 2003 | 01:40 PM
Mil1ion's Avatar
Mil1ion
wiring problems?
Get a heat shield for the starter.
I'll have to check on the other Q.
Old Aug 4, 2003 | 02:45 PM
macguyver's Avatar
macguyver
wiring problems?
The turn signal indicator is an indicator of a bad ground, usually in the back but not always. The parking/running light filament feeds back through the turn/brake filament making the indicator lamp in the dash glow.
Old Aug 4, 2003 | 08:25 PM
76supercab2's Avatar
76supercab2
wiring problems?
I don't think the two are related. From personal experience the lights are a bad ground. Is/was one of the turn signal lenses cracked? Check the sockets for corrosion. You may have to replace a socket but it's not that hard. I prefer solder/heat shrink tubing in this application.
Use a piece of wire and try grounding the bulbs. Go from the brass body of the base to the frame or metal of the truck. When the lamp on the dash goes out you have your culprit.
Good luck.
Old Aug 4, 2003 | 09:27 PM
okiebronco's Avatar
okiebronco
wiring problems?
alright guys. thanks for the help. i just bought a new project that ill be working on my next day off but i think i can make time to do it on the weekend. ill let you know what i find
Ed
Aerostar
Oct 31, 2007 12:13 PM
snagmaster86
Sep 13, 2006 07:28 AM
jpb222
Jul 28, 2004 10:39 PM
pcwb
Mar 18, 2004 03:52 PM
